Page 36 of 48 FirstFirst ... 2632333435363738394046 ... LastLast
Results 701 to 720 of 1853
    Aug 2013
    Quote Originally Posted by radz15 View Post
    Sa better living Paraņaque. Tataka nga ako bat ang mahal.
    Posted via Tsikot Mobile App
    P28 ang 2T power burn, bili ko sa petron dona soledad, baka 2T premium yung mahal, hindi ko lang alam kung pwede din ito mix sa diesel.
    medyo madami ng petron stations na may 2T premium. gray bottle ito. 2T power burn ay yung yellow.
    Jul 2011
    pati gasoline boy pinatungan na yung presyo. Kasi karaniwan wala naman kasi resibo yan at pag ganyan di agad binibigay sa cashier, binubulsa muna nila. Ganyan pumitik yung naging kasamahan nung nagkwento saken. At meron pang isang raket yung mga gasoline boy lalo na sa mga babae, yung hindi ugaling tumingin sa pump kung nakarga lahat, binabawasan nila ng karga ito, eto malupit minsan ginawa kalahati lng kinarga at nauubusan sa daan yung babaeng nagpakarga.
    Jul 2011
    Simple lang effect longer oil change interval.
    Combating harmful effects of sulfuric acid.
    Blanking or blocking EGR on crdi engines is another way to reduce effect of sulfur to introduce in combustion chamber, where soot, unburnt fuel high in
    sulfur(when specially adding 2T) recirculated to the intake, detrimental to piston rings and other that may corrode with acid.
    1:300 instead of 1:200 is what I found optimal to our innova.
    or 1L(diesel) : 3mL(2T)
    HTH
    Apr 2014
    Been using 2T (FC) oil in my Everest 2005 for one month now. So far all outcomes are positive.
    1) Increase in power: On a straight flat road at 100Kph, my new RPM reading is now at 2600. Prior to 2T oil it was 2750
    2) Some improvements on the Smoke emission
    3) Fuel consumption is yet to be determined but I guess there are some improvements as well but pretty much minor
    2T believer now and will continue to use this.
    Last edited by CarloCasem; April 22nd, 2014 at 03:04 PM. Reason: omitted one sentence
    Apr 2014
    Jul 2013
    2.5ml of 2T per 1L of diesel po ba? So 34L=85ml of 2T? Sorry mga sir naguguluhan lang
    Oct 2009
    Quote Originally Posted by zairus View Post
    on 1 : 200 mix ratio, 34Lx1000/200 = 170ml of 2T motorcycle oil
    Jul 2011
    read some articles and the high sulfur fuel may foul your metering for CRDi, dont know if thats the one affecting me before I tapered the ratio and switch to biodiesel or air filter due for replacement or the short distance trip. but when I reduced it with biodiesel much smoother low FC.
    May 2010
    Ang Motul Specific CRDi ba Low TBN?
    Jul 2011
    according sa net 10+ ang tbn ng motul crdi specific 5w-40.
    may dalawang rating akong nakita sa TBN ng delo 400, nasa 10 at 12+
    sabi ni dvldoc basta 10+ tbn ok na.
    May 2010
    ^Thank you for the info
    Jun 2011
    Ive been using 2t on my ranger t6 for 2 full tanks... Observation ko much smoother, lesser vibration and noise.
    Almost the same na ang vibration and noise level sa gas focus ko...
    Ranger t6 ko less than 2k kms. Palang ang mileage...
    Sent from my C2305 using Tsikot Forums mobile app
    Aug 2008
    ^what ratio are you using sir?
    Jun 2011
    More or less 5ml. - 1liter of diesel...
    1st full tank 2 bottles 200ml. of 2 t. Every succeeding full tank 200ml. Nalang... Or 2.5ml. Per liter of diesel... Hindi naman ako sakto maglagay... Basta 200ml. Kada full tank.. Observe ko lang malaki ang tinahimik... IMO sa t6 the best siguro 200ml of 2t sa 70liters of diesel
    Feb 2014
    Good day to all 2t users! Just wanna share my observations here regarding 2t mixed with diesel
    1. Shell 2t decarbonizer + petron turbodiesel
    Observation/s: less engine noise and vibration, same fc, same power
    2. Petron 2t powerburn + petron desel max
    Observation/s: back to normal engine noise and vibration, i can now maintain 1500-1800 rpm * 60-80kph compared before, better fc
    3 Petron 2t powerburn + Petron turbodiesel
    Observation/s: less engine noise and vibration, i can now maintain 1500-1800 rpm * 60-80kph compared before, better fc
    Quote Originally Posted by chris143135 View Post
    3. Petron 2t powerburn + Petron turbodiesel
    This is what I use. I pour in 2 small bottles for every full tank of fuel. The improvement is big. Some of my friends have told me that my 4m40 has only gotten quieter through the years.
    Feb 2014
    Ang ganda talaga ng response sir ng 4m40 sa petron powerburn at petron turbo diesel. Actually sa 4m40 ko pag Petron turbo diesel gamit ko tahimik makina compared sa dieselMax, then pag hinaluan ko pa ng 2t mas lalo tahimik. By the way I got tempted earliear to buy the Optimax 2t FC rated, i poured only 50ml with petron TD. testing lang, I'll share my observations probably in the next couple of days.
    Quote Originally Posted by K.I.L.L. View Post
    Apr 2017
    good day to all 2t users! Just wanna share my observations here regarding 2t mixed with diesel
    observation/s: Less engine noise and vibration, same fc, same power
    observation/s: Back to normal engine noise and vibration, i can now maintain 1500-1800 rpm * 60-80kph compared before, better fc
    3 petron 2t powerburn + petron turbodiesel
    observation/s: Less engine noise and vibration, i can now maintain 1500-1800 rpm * 60-80kph compared before, better fc
    so ano po b tlgang magandang klase ng diesel "petron" or ""shell""????
    Alam ko po it depends nmn sa sa2kyan dba??? Pero kau po mga ka-tsikoteers???? Ano pong mas prefer nyo na mas maganda, mas smooth at mas ok andthe best na tandem for our "2t oil"????? __petron diesels___ or __shell diesels___ feedbacks po.... Maraming salamat po sa inyo ;-) (my ride is elgrand qd32eti just like sir dvldoc have and 1999 toyota grand hiace 1kzte, the best ride!) tia.
    Had another 2T in my tank. Doing this for years now.
    Quote Originally Posted by zan View Post
    Musta naman sir? Ano experience mo?
Diesel owners that add 2T oil to fuel
