Page 41 of 93 FirstFirst ... 313738394041424344455191 ... LastLast
Results 801 to 820 of 1853
    Mar 2011
    #801
    Mga sir, pwede kaya haluan ng 2T oil ang 2010 hyundai accent crdi?
    Quote Originally Posted by stevilla View Post
    Yup, puwedeng-puwede. As long as hindi above 2,500 bar psi ang CRDi system puwede diya.
    May 2010
    #803
    which is which? 2500 bar or 2500 PSI?
    1 Bar is approximately 1 atm and 1 atm is equals to 14.7 PSI
    Quote Originally Posted by SiRbossR View Post
    My mistake, it should be not more than 1,500 BAR to be safe.
    Mar 2011
    #806
    Ry_Tower;2016491]Yup, puwedeng-puwede. As long as hindi above 2,500 bar psi ang CRDi system puwede diya.
    Any idea sir kung ilang bar psi ang crdi system ng accent?
    Not more than 1,500 pa sir so puwede.
    Fuel is supplied ..... from a cylindrical tube which is pressurized at about 1400 bars and fuel is injected at a pressure of 1350bar as compared to the 400-odd bars at which the fuel is injected in normal diesel engines.
    Feb 2012
    #808
    mga sir may expiration date ba ang 2t oil?
    Quote Originally Posted by sotel View Post
    As long as it is properly sealed in some sort of container it will be ok. Years ito puwede naka-stock. Hindi naman napapanis yan, naco-contaminate lang.
    Jun 2011
    #810
    Quote Originally Posted by limarj View Post
    try to locate a hose that connects from the cylinder head(cover) to the air intake. connect the oil catch can there. connection should be: cylinder head --- oil catch can --- air intake.
    sir pwede bang FUEL FILTER ANG gamitin as oil catch can? if yes... PAng anong sasakyan po na FUEL FILTER ang pwedeng gamitin? diesel engine nga po pala ride ko...
    The inlet of the fuel filter that you will use must have a hole bigger or at least same size as the outlet of the valve cover. This is to ensure free flow of blow by air. It also matter that the fuel filter is big enough to ensure no build-up of air which could damage your engine. That is why ideally, a fabricated or DIY OCC is to be installed to avoid problem.
    Jun 2011
    #812
    thanks sir.... sir where can i find a post or picture here at tsikot a DIY OCC?
    http://tsikot.com/forums/isuzu-cars-...install-41877/
    or ito.
    DIY Oil Catch Can for CA18DET Datsun 1600
    #814
    Just wanna share...
    Been adding 2T since I bumped into this thread, it's almost a year now. My engine is a 1KZ-TE subic Toyota Hi-Ace.
    1) Engine noise has been reduced a lot. Mas maingay pa nga yung ibang Toyota D4D engine at ibang Starex na mga 5 year old and above.
    2) Pag pinatay ko yung engine parang gasoline engine, wala na akong naririnig na shut off shudder gaya ng dati.
    3) Can't comment if there's any increase in HP, really hard to tell.
    Now, may tanong ako...Makakalinis kaya ng EGR valves ang paggamit ng 2T..? Natetemp kasi akong baklasin yung EGR ng van ko kaso ang daming tatanggaling turnilyo. So guys, do you have any experience about checking your EGR valves after using 2T for sometimes..?
    TIA..!
    Quote Originally Posted by erick_214 View Post
    Just wanna share...
    TIA..!
    Let's wait for first hnd experience. But technically dapat kahit papano makakareduce 2t sa deposits sa EGR. Pero the best solution kasi sa EGR problem ng old school diesels is the oil catch can installation.
    #816
    thanks. pwede ba to sa Starex 2006 Grx CRDI? i dont know how much bar psi ang system niya. thanks
    Dec 2007
    #817
    Quote Originally Posted by poorprince View Post
    You can use it on any Starex CRDI..
    #818
    Thank you Sir will try this out!
    Jun 2011
    #819
    sir DVLDOC can i use 2t on a Cummins Diesel GEnerator sets?
    pareho po ang engine ng gen. sets sa engines ng mga heavy equipment.
    Jun 2011
    #820
Diesel owners that add 2T oil to fuel
