Page 21 of 93 FirstFirst ... 111718192021222324253171 ... LastLast
Results 401 to 420 of 1853
  1. #401
    My LD20II in my nissan vanette is very happy with it. Madalas nangyayari inaamoy ng mga gas attendant yung fuel cap ko before filling para manigurado kasi parang di sila naniniwalang naka diesel engine na ako. Most of the time they ask me, "Diesel? Diesel na po ba yan?......."Sir full tank, diesel ha?"
    Masasabi kong detonation noise sa cylinder head is almost at par with some CRDI's na naririnig ko. May be different for other bigger old school diesel engines (mine is only a 2.0L)
    Aug 2011
    #402
    Quote Originally Posted by BoyBawang View Post
    Hi sirs is it ok to use with my innova D4D 2010 mdl engine... do I really need to have a full tank before i can pour the oil in with the diesel?
    So either Jaso FB or FC will suffice? whats the proper ratio? TIA ;) im learning soemthing new here
    Pareng Boy Bawang, start reading from page 1.
    Feb 2012
    #403
    hello po newbie here...ask ko lang kung ok lang ba maglagay ng 2t sa starex grx 2005 crdi?
    thank you...
    Dec 2007
    #404
    Yes you can add it to any year Starex.
    Feb 2012
    #405
    Thank you dvldoc for your responsed. try ko sa next fillup ko ng diesel. ask ko lng wala naman kaya maging effect sa engine ng isang CRDI? engine is D4CB.
    #406
    Quote Originally Posted by star-x View Post
    sir, try to backread. makikita mo lahat ng answer sa tanung mo.
    #407
    bought 3L worth of castrol 2T in cash and carry. its 120pesos/L
    Same here, yan pinaka-urang 2T eh. hehe
    Sometimes shell 2T.
    Sep 2008
    #409
    Quote Originally Posted by alwayz_yummy View Post
    so regardless kung anu 2T binili mo, results will be the same.. scents nalang ba? kasi nakikita ko ibang 2t scented daw ayon sa label..
    btw.. on 2T na din ako sa carens.. diesel max+2T on 1L-5ml ratio muna, dati kasi shell fuel save kaya siguro di maganda manakbo.. mas mura pa din than using petron's turbo diesel.. tsaka medyo nag-smooth out na ang takbo after around 500kms of use, lesser soot pa sa tail pipe end..
    [/I][/I]
    Does this mean that shell fuel save + 2t oil is not compatible? I plan to use 2t oil for the first time on my Innova d4d when I get back to Dagupan this weekend. What's with shell fuel save btw that it would not, if indeed, be compatible with 2t oil? TIA...
    #410
    Sometimes shell 2T.
    actually naghahanap pa ako ng autosupply na cheaper pa yung benta hehe im sure may mas mura pa. baka sa mga motorcycle shops mas mura hehe
    #411
    I also started putting 2T from shell in my crosswind but there was this incident that my aircon smelled like fuel, so I stopped I'm not sure if it was just a mere coincidence, does anyone had this experience?
    Jun 2011
    #412
    sir baka po nung nagkakarga ka naka a.c. ka.. kaya nahigop ng a.c. mo ang fumes ng diesel or ng gas station, or baka nakatapak ka ng diesel pag sakay mo ayun umamoy na po... hindi po connected ang a.c. sa fuel system natin... coincidence lang po yun...
    Jul 2011
    #413
    baka nga sir co-incidence lang yun...ako nga sir 1st gen CRDI ok naman takbo pino, nung una na obserbahan ko pag nahiram at na full tank ng wala 2t di pino ang vibrations na maikukumpara mu pag may halong 2t lalo na sa unang start,,, lalo na siguro po sa inyo crosswind. naalala ko tuloy kwento nung may-ari ng isang xwind pinagdrive misis nya at subukan daw nya mag passenger, wtf daw walang silbi ang headrest monitor sa sobrang liit at nanginginig pa di mo din mapanood maayos NAHILO lang daw xa LOL...
    #414
    Quote Originally Posted by mumuy View Post
    [/I][/I]
    I use Shell 2T with shell fuel save - no problems at all. Might have been bad or contaminated fuel
    Sep 2008
    #415
    Quote Originally Posted by edtf View Post
    Thank you po for the reply. Sir is your ride also a CRDI?
    #416
    Kia Carnival - crdi
    4d56t & 4JG2
    all shell fuel save with shell 2T
    Feb 2012
    #417
    I used caltex diesel w/ techron and shell 2t...ok lang kaya 'to?
    Jul 2011
    #418
    bakit di na lang din caltex havoline 2T mix mu sa caltex diesel mas mabango pa promise
    Feb 2012
    #419
    Quote Originally Posted by MrQ5 View Post
    *MrQ5. na try mo na ba havoline 2t and caltex diesel? pro sa next fill-up ko ng diesel sa caltex i-try ko havoline 2t...
    Jul 2011
    #420
    nope to catex diesel, loyal ako sa petron dieselmax sa isang gas station dito para ma monitor ko tunay na FC at yung iba kasi gas station pag di mu kilala di accurate ang calibration nila kaya ang refill nila kulang karamihan, yung isang gas station dito napansin ko nag pa full tank ako ilang beses mas maikli na naitatakbo ni innova kesa sa dieselmax. dieselmax + 2t po ako.
Diesel owners that add 2T oil to fuel
