Results 2,321 to 2,330 of 2348
- Jan 2008
- 4,726
October 20th, 2018 07:23 PM #2321
- Oct 2018
- 12
October 20th, 2018 09:20 PM #2322
- Jan 2008
- 4,726
October 20th, 2018 10:33 PM #2323
- 54,205
- Apr 2008
- 6,235
October 20th, 2018 11:32 PM #2325Hmm... You mentioned that there are no problems once it is running. So I am inclined to believe that there is no problem in the engine itself.
I would first check the starter motor, battery and alternator. Then perhaps also the glow plugs, fuel filter and fuel pump.
Sent from my SM-G900I using Tapatalk
- Oct 2018
- 12
November 2nd, 2018 06:52 PM #2326
- Oct 2018
- 12
November 2nd, 2018 06:54 PM #2327nacheck na lahat bago na din battery at fuel pump pero nawawalan parin ng pressure fuel pump ko parang nagkakhangin kaya kailangan munang ipump at apakan accelerator para mastart
- Apr 2008
- 6,235
November 2nd, 2018 07:36 PM #2328
- Nov 2009
- 3,507
November 2nd, 2018 07:40 PM #2329Napalitan na fuel filter? Ifyou are suspecting air in line, try to install transparent chemical hose in between fuel filter and injection pump and between fuel filter and fuel inlet pipe and check where the air is coming, it could be the primer bulb leaking or cracked fuel hose.
- Oct 2018
- 12
November 2nd, 2018 07:49 PM #2330
Buti nalang hindi binintang yung kotse since hindi naman siya monterosport. It would be different...
