Hello,
I replaced the glow plugs the first time since I got the car in 2004, so I don't know when they were last done. One had a slightly broken tip and the others had a mix of bad and good so it was timely. I heard Beru is better but harder to acquire, Bosch makes up for it with availability though. Either way it's a win-win situation. When it gets hot it's actually hotter than it is there, so the temperature fluctuations are rather broad. Once it's cold it gets really cold too, last week it was down to the 40's (degrees Fahrenheit, which is roughly single digit Celsius readings). Still not a problem with my car.
By the way I meant to ask you, what do you think of Monark versus Bosio nozzles for the OM617.952 engines? There were several versions of the Monark that were released. See related thread here:
http://www.mercedesshop.com/shopforu...d.php?t=207859
Also one more thing, the non turbo versions of the OM617 that use the series type glow plugs can be upgraded with the parallel type glow plugs. Have you heard of this? I'm pretty sure a lot of MB owners there that have 1979 and older cars would love to get their hands on a kit like this installed on their diesels. My friend who has a 79 300TD recently had the kit installed but one problem was the availability of the "fast" glow plugs. Here they cost $12.xx while the turbodiesel versions (smaller but also fast glowing) cost $10 at the local Autozone. Rewiring has to be done for the parallel type but that's not so difficult. See what he did here:
http://www.runboard.com/bmercedesben...sinc.f5.t13234
I did not notice any transverse shaking at that engine speed, perhaps it's due to the large air cleaner mounted high on the engine bay allowing for a pendulum effect? Those air cleaner mounts could have been designed better though. Doesn't the "rack dampener pin" at the back of the injection pump dampen the vibrations? This device was only found on the turbocharged engines though. Maybe the non turbo versions had the vibration, something I have never experienced having only owned the turbodiesel models, a 1981 300TD-T and a 1983 300D both US version turbodiesels.
I recently graduated here so I plan to work full time already, so I can get my wife over.My field is completely different from anything automotive.
