Page 233 of 235 FirstFirst ... 133183223229230231232233234235 LastLast
Results 2,321 to 2,330 of 2348
    Jan 2008
    #2321
    Quote Originally Posted by Jawe View Post
    Hard starting siya at sa start may white na usok. kahit mainit pa ang makina minsan ayaw mag start nahihirapan. starting lang naman ang problema pag nakaandar na at tumatakbo maganda naman ang takbo. minsan may pinuntahan kami pinatay tas after 20 mins instart hanggang redundo lang. ano kaya problema nito mga boss?
    Lagay mo kaya kung anong engine yan? Crdi or conventional? Ilang taon na? Etc. Kulang kasi impormasyon mo eh
    Oct 2018
    #2322
    Quote Originally Posted by maxpedition View Post
    Baka battery mo? O pacheck mo alternator mo
    bago na ang battery napacheck ko na din alternator okay naman
    starex '98 d4bb
    Jan 2008
    #2323
    starex '98 d4bb
    Malayong kamag anak yan mg 4d56 ng mitsubishi.. napalitan mo na ba glow plugs?
    #2324
    are you losing water/coolant?
    does your oil level go down fast?
    Apr 2008
    #2325
    Hmm... You mentioned that there are no problems once it is running. So I am inclined to believe that there is no problem in the engine itself.
    I would first check the starter motor, battery and alternator. Then perhaps also the glow plugs, fuel filter and fuel pump.
    Sent from my SM-G900I using Tapatalk
    Oct 2018
    #2326
    Yep napacheck na namin glowplugs the problem is parang nawawalan ng pressure yung fuel pump kailangan muna naming ipump tapos apakan accelerator para magstart
    Hindi naman
    Oct 2018
    #2327
    Quote Originally Posted by GTi View Post
    nacheck na lahat bago na din battery at fuel pump pero nawawalan parin ng pressure fuel pump ko parang nagkakhangin kaya kailangan munang ipump at apakan accelerator para mastart
    Apr 2008
    #2328
    Ganon? Do you have black smoke? Perhaps injection pump calibration is in order?
    #2329
    Napalitan na fuel filter? Ifyou are suspecting air in line, try to install transparent chemical hose in between fuel filter and injection pump and between fuel filter and fuel inlet pipe and check where the air is coming, it could be the primer bulb leaking or cracked fuel hose.
    Oct 2018
    #2330
    walang blacksmoke ang meron white smoke tuwing start mapa umaga man or tangahali pero sa starting lang pag tumatakbo wala namang white smoke
Diesel Fuel Injection System Help Desk
