Results 2,051 to 2,060 of 2348
August 20th, 2013 10:29 PM #2051
Per num 1. Confusing as all articles I read over the net says egr stays closed when idle as if it is open the engine will misbehave causing erratic idling. The way I understand it is that it behaves in extremes. Closed in idle then open mid cruising then closed again in wot.
Sent from my GT-I9082 using Tapatalk 2
- Feb 2012
- 19
August 21st, 2013 01:28 AM #2052my 1997 Kia Sportage RF TDI 4x4 had a very poor FC. Computed 7km/liter (city driving) with AC ON, driving in a very light traffic.
Maganda ba ang andar? No excessive white ot black smoke?
No Black Smoke, Ok ang Acceleration, Start/Cold Start, top speed 115Kph. Matakaw lang talaga sa Crudo
Injectors was calibrated twice this year Why was injector calibration done 2X in one year?
Nagdududa ako sa 1st probably pinagperahan lang ako, pakita ng resibo kunwari, so the 2nd mechanic Recalibrate but he shown to me na maitim na ang nozzle at magaspang na
Injection pump is new (1 year old) New pump has the same part number as the original pump? YES
Fuel Lifters is new (1 mo old) What do you mean by fuel lifters? Opps my bad, its Diesel Primer Pump both Filter and P Pump are Bnew
Air Filter is new (2 weeks old)
Engine Oil is new (10w-30 wid X1R)
Oil Filter is new (4 months old)
its suppose to be driving at 12km/liter malayo masyado sa 7km/liter.
1.) anu at saan kaya ang may problema? bakit lakas uminom ng sportage ko?
Bbaka wala sa timing ang injection pump. Hanap ako ng Mekaniko para dito
2.) ipa recalibrate ko ulit? kxi nakakaduda ang 2 calibrations
Dapat once lang ang injector calibration kung kumpleto sa test equipment and test data ang diesel workshop.
3.) totoo kaya baka butas na masyado injectors neto? (220k nsa odometer)
Papalitan ko na ang nozzles kung 220k na ang tinakbo nito. Tama Lagi Laspag na ang mga injectors
Follow-up Questions
1.) Magkano Budget ko para sa 4 na nozzles? 700 daw kada nozzle?
2.) Pati ang pagpapa Timing ng Injection Pump magkano kaya?
Maraming Salamat sa inyong advice. :
- Sep 2006
- 1,335
August 21st, 2013 12:33 PM #2053[QUOTE=van1029;2208117]my 1997 Kia Sportage RF TDI 4x4 had a very poor FC. Computed 7km/liter (city driving) with AC ON, driving in a very light traffic.
Follow-up Questions
Hindi ko alam ang tamang nozzle part number........can't give you a price.
Can't quote, dapat makita muna ang engine para ma-estimate ang labor. Bihira pumasok sa amin ang '97 Sportage.
- Sep 2013
- 4
September 19th, 2013 05:54 PM #2054Gud pm, Sir,
Bago lang po ako sa forum.. May tanong lang po ako tungkol sa engine light ON sa dashboard.
Bigla pong iilaw yung engine Light ON pag nakahinto po ako, tapos tatabi lang ako at i-turn off ko yung engine. Then, start uli (one-click) tapos wala na po yung ilaw sa engine. Hindi naman po nagbabago yung hatak at tunog ng engine.
Hindi rin po madalas nangyayari ito. Sa pag gamit ko ng 4 na buwan mga 10 beses pong umulit ito. Lumapit na po ako sa CASA, kaya lang ang sabi nila hintayin ko uling umilaw yung engine light para madiagnose nilang mabuti. Kya lang ayaw magpakita sa kanila eh!
Naobserbahan ko po, pag nakahinto ako at naghand-brake, mga ilang Segundo lang iilaw na yung Engine light. Ano kaya ang problema? Sana matulungan po ninyo ako.
Yung VAN ay - 2nd hand, Innova 2006 E, MT, Diesel, 56K – odo; fuel – Diesel V shell
thanks
BANNED BANNED BANNED
- Feb 2013
- 487
September 19th, 2013 07:30 PM #2055Ganito yan para madali mo maintindihan at i-explain mo sa casa.
Di kailangan na magpermanent na check engine light ka para malaman nila na may problema. Ibig sabihin na nag check engine light ka, may problema na sasakyan mo pero intermitent pa ito for the meantime kaya ganun rin ang pag ilaw nya.
Ipa scan mo ang sasakyan mo sa pinakamadaling panahon bago pa mag permanente na ilaw yan.
Sa totoo lang, ang engine or ecu scanning ay dapat kasali sa PMS ng mga sasakyan na may ecu, kasi kahit di man umilaw ang check engine light, may mga errors yan na naka log sa memory.
Sa scanning mo rin makikita kung fuel efficient pa sasakyan mo at yung mga threshold/limits ng mga sensors mo.
- Sep 2006
- 1,335
September 20th, 2013 07:51 AM #2056Tama si siopaona toasted. Meron kang intermittent fault.
Normally, makikita ng scan tool ang fault ng car kahit off ang check engine light dahil naka save ang fault sa computer box as passive or historic event.
Mabubura ang passive faults ng scan tool, o sa pagtanggal ng battery connection for a few minutes. Hindi mabubura ang active faults.
- Sep 2013
- 4
- Sep 2013
- 4
September 20th, 2013 02:15 PM #2058Sir DD, pwede bang dyan mag pa scan sa shop ninyo at magkano kaya ang aabutin?
October 2nd, 2013 03:24 PM #2059
SIR DIESEL DUDE..
where is your location?
baka po dyan ko nalang ipadala for repair and check up nung CAR ko na diesel na kinargahan ng gasolina..
ANYONE here who knows diesel dude shop location?
October 2nd, 2013 03:33 PM #2060
Central Diesel in Q.Ave. cor. Sct. Magbanua
Home | Central Diesel (Philippines)
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
