Page 143 of 235 FirstFirst ... 4393133139140141142143144145146147153193 ... LastLast
Results 1,421 to 1,430 of 2348
  1. #1421
    Quote Originally Posted by Dieseldude View Post
    This is very unusual. Injection pumps don't normally rattle. Noise could be coming from some part of the engine, near the pump.
    The rattle sound is more of like the sound a bicycle sprocket makes when you free-wheel it but is very audible. I tried moving the throttle by hand and the pulses of the rattle sound can be felt on the pump assembly.
    Makes me wonder....
    Sep 2006
    #1422
    Quote Originally Posted by kompressor View Post
    Makes me wonder....
    Injection pump mounting may have come loose. Also check injection pump drive mechanism.
    #1423
    Hi Dieseldude. I got my mutant green rover with the leaking injection pump yesterday and used it today. Good as new! Practically zero smoke and I will check out my mileage by next week. really happy with it. Makes me want to have my 4d56 done too.
    Sep 2006
    #1424
    Quote Originally Posted by edtf View Post
    I am glad that we were able to help! Enjoy your ride
    #1425
    sir dieseldude, good day po! i'm from leyte province and i have a 2004 crosswind xuv 4ja1 engine , patulong po sana ako regarding with my engine problem, napalinis and na pa check ko na po yung mga injectors, aircon system and alternator ok naman po. ang problema po kasi naka andar na po ang makina at na ka on ang aircon and nasa normal level na ang temperature kahit nasa normal rpm ang idling nag wild ang makina. pero kung naka off ang aircon, ok naman ang andar ng makina. may problema na po ba ang injection pump ko? may idea po ba kayo kung magkano ang gastos sa magpa calibrate? saan po ang recommended nyo na shop na maka pag papabalik sa original setting ng injection pump? i've heard na magaling daw po ang malabon diesel shop, ok po ba? sana po matulongan nyo ako. thanks in advance and God bless.
    May 2009
    #1426
    Good day Sir DD,
    Problem here: Isuzu Elf truck 4GG1 NA engine. No hard starts. Practically no smoking on idle but smokes a little "off white" on highway runs especially on acceleration. Sluggish power on acceleration producing that kind of smoke.
    One specialist quoted P20k on calibration. A good price? I really don't know for now.
    Thanks in advance for any comment and suggestion.
    Sep 2006
    #1427
    Good day Sir DD,
    Problem here: Isuzu Elf truck 4GG1 NA engine. This is the first time I hear about an Isuzu 4GG1. Could it be a 4JG1? Is this an electronic engine?
    No hard starts. Practically no smoking on idle but smokes a little "off white" on highway runs especially on acceleration. Sluggish power on acceleration producing that kind of smoke. Was any previous work done on this engine that may have caused this problem?
    One specialist quoted P20k on calibration. A good price? I really don't know as I've never heard of this engine type.
    Thanks in advance for any comment and suggestion. Check pump to engine timing.
    Sep 2006
    #1428
    sir dieseldude, good day po! i'm from leyte province and i have a 2004 crosswind xuv 4ja1 engine , patulong po sana ako regarding with my engine problem, napalinis and na pa check ko na po yung mga injectors, aircon system and alternator ok naman po. ang problema po kasi naka andar na po ang makina at na ka on ang aircon and nasa normal level na ang temperature kahit nasa normal rpm ang idling nag wild ang makina. pero kung naka off ang aircon, ok naman ang andar ng makina. may problema na po ba ang injection pump ko? Baka mali lang ang adjustment ng idle-up device. Itinataas nito ang idle rpm pag on ng aircon compressor para hindi bumagsak ang idle rpm, at para rin hindi patayin ang engine. Malakas ang engine shake kung masyado mababa ang rpm.
    may idea po ba kayo kung magkano ang gastos sa magpa calibrate? 8 - 12K
    saan po ang recommended nyo na shop na maka pag papabalik sa original setting ng injection pump? I will PM you.
    i've heard na magaling daw po ang malabon diesel shop, ok po ba? Malabon is ok.
    May 2009
    #1429
    Good day Sir DD,
    Oops. Sorry sir. 4HG1. had a talk with the driver-operator recently. the unusual smoking and sluggish power occured after filling-up with diesel. drained the fuel filter-separator. still there is white smoke. I suspect a water contamination problem with the fuel station. will fill up again another batch of diesel and see what happens.
    no previous work done on the vehicle except the regular oil and filters(oil, air, fuel) replacement. it was a surplus unit and running for 2 years now. the problem occured last week.
    thank you sir
    #1430
    sir dieseldude, kung inilalagay yung rpm 750 na may load na aircon which is ito naman ang naka lagay na normal idling, yun na nag wawala na ang engine. pero kung ibinababa naman sa 650 na may load na aircon hindi na nagwa wild. pero pag walang load na aircon ok at ang ganda ng andar ng makina patri ang hatak ok.. salamat po sa reply nyo kanina. sana po matulungan nyo ako.
Diesel Fuel Injection System Help Desk
