Page 71 of 118 FirstFirst ... 216167686970717273747581 ... LastLast
Results 1,401 to 1,420 of 2351
    Sep 2006
    #1401
    Quote Originally Posted by laronde View Post
    need help po with my L300FB i cant
    start it eh, nagcracrank naman siya.
    already replaced the fuel filter,
    cleaned the air filter too, napaltan na
    rin battery but still ayaw parin
    magstart. is it possible that there is a
    problem with fuel injection ayaw kc
    magpump ung fuel filter
    1) The hoses on your fuel filter may have been connected the opposite way? There is a one way valve in the filter base.
    2) You may have a suction leak?
    3) Absence of +12 volts to the injection pump solenoid or a failed solenoid coil?
    4) Faulty injection pump.
    Aug 2011
    #1402
    thanks po sir. actually gumana npo recently ung fuel filter niya pero ayaw parin magstart eh. pinalitan narin po ung mga glowplugs tsk. ayaw parin madalas nga madrain battery ko dati dahil dun
    Aug 2011
    #1403
    Quote Originally Posted by Dieseldude View Post
    thanx sir pinatingnan po namin knina sa mekaniko sabi wala raw pumapasok na kuryente sa glowplugs? kaya hindi makapagpreheat at ang result. ayaw magstart. thanx sa advise
    Sep 2006
    #1404
    Yan yung recommended fix kasi sabi mo ayaw mag pump ng fuel.
    Pa-check mo ang wiring, glow plug relay, or preheat controller kung walang kuryente sa plugs.
    Good luck.
    Aug 2011
    #1405
    sir galing mo talaga starter relay nga
    daw po problema. possible po ba na marepair pa ung starter relay ko. nilagyan nlang ksi ng mekaniko ng push button switch ung glowplugs para gumana. thanx sir
    Sep 2006
    #1406
    Ipabalik mo sa original connection. Hindi tama yung mag convert sa push button switch dahil meron timer ang original system. Mapupundi ang new glow plugs mo kung mapatagal and push mo.
    #1407
    Hi Dieseldude, I have a leaking injection pump on my isuzu 4jg2 engine. Would you know how long will it take to rebuild it? Looks like I will be visiting you on Monday morning. Hope to see you
    Sep 2006
    #1408
    Quote Originally Posted by edtf View Post
    1 - 2 days, depending on our work load.
    #1409
    ok will be at your shop first thing in the morning
    Dec 2003
    #1410
    My oil level is rising. This happened between oil changes. Could this be caused by a leaky injector? How about a faulty oil filter anti-drainback valve? Performance and fuel consumption is normal. What signs to look out for before I bring it in for a check up?
    Vehicle is a Mitsubishi Adventure. Engine is 4D56 NA.
    Sep 2006
    #1411
    Quote Originally Posted by RustyXIII View Post
    This is probably an injection pump problem; worn drive shaft, bushing, and seal.
    #1412
    sir, got this from Pajero Club. can this be IP problem?
    Hi, I have a 2005 4x2 A/T Pajero localy bought it. Yesterday we had a freek accident. While i was about to leave a compound, the acceleration went burzerk. The RPM suddenly rise to max (6000) redline without even touching the accelerator pedal. In just split seconds i wasnt able to control the Pajero and ended up hitting a CRV, 2 trycyle, a Van and destroying a property (Party needs store), luckily no one was seriously wounded. I was hoping if you can give me some idea on what went wrong with my Pajero or does anyone encounerted this already.
    Dec 2003
    #1413
    Thanks for the quick reply. Would a faulty IP show other signs aside from overfueling? A dip in performance perhaps or increased/different colored smoke?
    Sep 2006
    #1414
    This could be due to excessive oil discharge from the PCV being routed back to the engine's air intake system.
    2005 would imply that this is an electronically controlled engine. Faulty accelerator pedal position sensor or faulty wiring from the pedal sensor to the ecu could also cause this problem.
    Sep 2006
    #1415
    A faulty injection pump can exhibit a lot of unpredictable performance problems. This depends on the particular problem within the injection pump.
    In your case, it is fuel-to-lube oil dilution. The next predictable problem will be difficulty in starting, not to mention the high probability of engine bearing and crankshaft failure to to poor lubrication.
  16. #1416
    Would anyone know if Betan or Central Diesel accept credit card payments for their services? I want to have my injection pump checked since I'm hearing a rattling noise in the injection pump. So far, no smoke and loss of power but this noise really annoys me.
    Dieseldude, what may be the causes of rattling in the injection pump?
    #1417
    sir, can it be the TCU? someone in Pajero club also suggested that the culprit can be the TCU.
    Sep 2006
    #1418
    Quote Originally Posted by kompressor View Post
    This is very unusual. Injection pumps don't normally rattle. Noise could be coming from some part of the engine, near the pump.
    Sep 2006
    #1419
    No, TCU cannot cause an engine to run wild. Btw, I suggest that this car be brought to a qualified diesel workshop. This is not for DIYs.
    Sep 2006
    #1420
    With regards credit card payments, check their websites.
Diesel Fuel Injection System Help Desk
