A mechanic has replaced the water pump unfortunately there are no timing marks on the cam, injection or crank pulleys.
After the assembly, the engine took some time to start (run at idle for a few minutes then turned off the key). After the mechanic left It is still hard to start and it died. My brother filled the tank with one gallon of diesel. then it started but there is some terrible noise as if an injection noise or a high pitched metal noise.
Actually I left the mechanic with my brother and never witnessed the first or second start ( I had something important to do).
Is our camshaft or piston or valved already destroyed?
