Results 1 to 20 of 2351
    May 2011
    Wow, this thread is sooo cool and informative!!! Great work here Boss DD!
    While I am on the process of back tracking, I'll post a question:
    I currently have a pickup with the 4JB1 Engine, in the "far" future (got it brand new, 3000kms pa lang) can I:
    1. Change the engine to a Turbo variant?
    2. What are the possible engines that I can put in? (Minimal or no modifications)
    3. How hard will it be to find and install the Turbo engine?
    4. Who are the "recommended" shops?
    5. The last question will be... COST. (^_^)
    Thanks in advance and more power!!!
    May 2007
    Good day Dieseldude and I appreciate your kindness in accommodating all questions/problems.
    I would just like to ask if replacement of injection nozzles always entails fuel pump calibration? I had my injection nozzles replaced and calibrated but since the mechanic said that the fuel pump doesn't seem to have any leak or something so he advised against tampering/calibration of fuel pump. Is this okay?
    Thanks!
    Sep 2006
    I would just like to ask if replacement of injection nozzles always entails fuel pump calibration? No, not necessarily.
    I had my injection nozzles replaced and calibrated but since the mechanic said that the fuel pump doesn't seem to have any leak or something so he advised against tampering/calibration of fuel pump. Is this okay? Yes this is fine. Your mechanic was trying to help you. Are you happy with your car's present performance?
    Thanks! You're welcome!!!!!
    May 2007
    Quote Originally Posted by Dieseldude View Post
    Dieseldude, yes I am happy with my van's performance after replacement of injector nozzles. Less black smoke and more responsive. Thanks.
    May 2008
    good day sir dieseldude,
    hingin ko po sana expert opinion/advice nyo regarding increasing the boost of 4d56tdic engines by putting washers underneath the wastegate actuator can, as per initiated by our respected tsikot top members..
    i personally installed the modification on my ride (95 pajero local) and power difference is very much noticeable..
    eugene
    Sep 2006
    Quote Originally Posted by eugene emmanuel View Post
    eugene
    Wastegate was probably out of adjustment and dumping exhaust gasses.
    May 2008
    is this safe for the engine sir?
    any negative effects?
    thanks in advance..
    Sep 2006
    thanks in advance..
    The wastegate controls maximum turbo rpm, and should be adjusted to your engine's specs.
    May 2008
    thanks for the info sir.
    Sep 2006
    1. Change the engine to a Turbo variant? Yes, if you are willing to spend.
    2. What are the possible engines that I can put in? (Minimal or no modifications) This is up to you.
    3. How hard will it be to find and install the Turbo engine? Go to Banawe and ask around.
    4. Who are the "recommended" shops? I can't suggest any at the moment.
    5. The last question will be... COST. (^_^) Only you can answer this after you've done the necessary homework.
    Thanks in advance and more power!!! You're welcome....
Diesel Fuel Injection System Help Desk
