dieseldude, just need your expertise on my hard starting problem:
My ride: '04 Starex GRX TCI w/ ECU
symptoms: 1. hard starting even when engine is already hot... better chances of making it start when engine is cold overnight.
2. not so erratic idling speed; with a/c on rpm is at around 900 but dwindles down to 800 for a second then back to normal
3. sometimes when i step on the acceleration after a cold start, no revving. just idling.
4. occasional "delayed response" when accelerating. bagal umangat ng rpm.
5. parang umingay na makina na parang umaakyat ng baguio pero i can easily reach 120kph sa SLEX. maingay nga lang.
When the symptoms started to appear, I brought the unit to hyundai casa and was diagnosed to have a dirty fuel filter (glow plugs checked in working order), hence was replaced with a new OEM fuel filter. Starts were manageable but lasted for only 5 days then hard starting again taking me atleast an hour of bleeding the fuel pump and trying to start again. brought it back to casa, then diagnosed with air entering fuel system due to leak "probably" sa filter pump mismo. Had a 2nd opinion from another mechanic, ayos naman daw ang pump maganda naman. most probably daw sa injection pump yan. unfortunately pinuntahan ko na mga calibration shops dito sa south of alabang di pa daw nila naseservisan ang mga injection pump ng starex na electronic. wala daw silang machine na nag fefeed ng current.
Sir ang tanong ko: 1. Could these symptoms pinpoint specifically to injection pump problem?
2. Ano kayang parts ang pwedeng affected sa situation ko?
3. If possible a rough estimate kung magkano gagastusin pag pinaayos sa calibration shop na gumagawa ng electronic controlled injection pump.
4. Gusto ko sana dalhin sa shop nyo para matingnan if you would be able to supply me the address of your shop. I just hope it starts para madala ko sa shop nyo.
