Hi can anyone identify these 2 pictures for me? car is a nissan patrol safari 1993 td42
1.) the hose in the picture is not connected to anything. parang putol or ganito ba talaga siya? is this a breather or what? i just wanna make sure kasi baka dapat naka connect to pala to something tas na tanggal lang
I am not sure coz I don't have the vacuum circuit for this vehicle. My mechanic says that this is an idle-up device which should be hooked up to a solenoid valve..
2.) what is this hose for? Not sure again. galing siya sa vacuum pump behind the alternator. kaya lng nag leleak ng oil din yung hose nato.
-is there a problem with the vacuum pump or seal? Possible.
-mechanic disconnected the terminal na kadugtong nito kasi it keeps the handbreak lights on lagi. baka grounded bec of the oil? Something may be wrong with the car's handbrake circuit.
THANK YOU! Try to ask Rion, fellow Tsikoter. He has access to lots of info, and might be able to give you correct info on this car's vacuum lines.
