My mechanic suggested to do a top overhaul first to check the oil leak he suspects that the valve seal is the culprit since wala naman ibang leak sa engine. I ask him also to change all the fuel line hose, check the egr, change the air element and fuel filter to oem.
Sir affected din ba shifting ng AT from first to second gear pag cold pa yung engine pag faulty yung fuel injector? I'm experiencing this every morning pero pag normal temp na yung engine wala naman problema shifting, yung first to 2nd gear lang talga problema sa umaga.
