Page 33 of 118 FirstFirst ... 232930313233343536374383 ... LastLast
Results 641 to 660 of 2351
    Sep 2006
    #641
    madami ako nkikitang mausok na 2.5 innova specially pag biglang tapak ang driver. Pero in my case sa strada wla ko nkitang smoke na mkikita mo sa side mirror while cruising 180 km/hr. Check mo sa casa, alam ko yan amg madalas na reklamo ng mga innova owners. Totoo yan dahil mas madami ang Innova kaysa Strada DID.
    Diseldude bkit yun hi ace d4d ng pinsan ko gingamit sa pamasada pero wlang usok, but yun innova same engine sila pero mausok yun iba at injector problem. Hindi natin alam yan. Dalawang sasakyan lang ang comparison natin. Baka na tyempo lang na may problema yung Innova...
    meron ba silang difference sa internal parts like injectors? thanks. Hindi ko alam dahil hindi pa ako nakakita or naka repair ng Hi Ace injectors.
    Sep 2006
    #642
    Quote Originally Posted by RR27 View Post
    >hi' at 130kph normal lang ba na umusok ang innova 2.5 D4D...??? 20k na odo niya 11months old pa lang...''' ok' thanks...'
    Depende kung gaano kakapal ang usok...Nasa pagtingin mo yan. Kung pasado sa smoke emission test, ok ang car...
    Apr 2008
    #643
    Quote Originally Posted by Dieseldude View Post
    >ok' thanks'
    #644
    Like is said from the very beginning...... one at a time lang. Wag sabay sabay. You have to know what was really causing your problem... And it will be very costly if they do these work scopes altogethr.
    Grand billing yan. Kawawa ka naman...
    so far ang plano ko is observe muna after this ATF / fuel filter change.... medyo laking abala na rin kasi ... hav to commute to work and I can't stay as late at work as I can kung may ride ako, compared to when I have to commute... mas konti tuloy ang natatapos ko... hopefully these fixes would fix the problem.. if not... parang i'm more inclined to really change rides na lang...
    #645
    to dieseldude,
    i would like to ask kung anu mas maganda engine pag dating sa diesel, hyundai sante fe 2.2 4x4 AT or MONtero MT 2.5 4x4
    gusto ko sa montero is manual siya, pero mas gusto ko ang SF kaso AT siya.
    anumas matibay na gawa ng injectors ? hyundai ba or mitsu, meron na kami 3.2 mitsu so far wla akong poblema sa engine, can hit 190 km/hr.
    thanks
    Sep 2006
    #646
    Quote Originally Posted by marktriton View Post
    to dieseldude,
    thanks
    Sorry. I'm not qualified to answer your question. Haven't had much experience on Sta Fe and Montero.
    Mar 2003
    #647
    sir dieseldude, how do I test kung mataas ang egt ko? thermometer lang ba sa exhaust? and what temp range ang safe for turbo diesel?
    and im kinda lost, ive been reading about egr, and one benefit of egr is lower egt, how come mas lalamig ang exhaust kapag hinalo sa intake ang exhaust gas? diba mainit ang exhaust sa outside air?
    Sep 2006
    #648
    sir dieseldude, how do I test kung mataas ang egt ko? Maximum EGT can be attained only when the engine is at full load. It is almost impossible to get this while driving on the road. You can simulate this condition when the car is on a chassis dynamometer.
    thermometer lang ba sa exhaust? Yes, but is is often called a pyrometer, attached to the hottest part of the engine, which is the turbo's exhaust port.....
    and what temp range ang safe for turbo diesel? The engine manufacturer dictates this. Range is from 250 deg C to 450 deg C.
    and im kinda lost, ive been reading about egr, and one benefit of egr is lower egt, how come mas lalamig ang exhaust kapag hinalo sa intake ang exhaust gas? EGR slows down combustion because the engine is receiving less oxygen.
    diba mainit ang exhaust sa outside air? Correct.... but exhaust air has less oxygen content.
    Mar 2003
    #649
    thank you sir dieseldude.
    #650
    Update lang po on my Innova problem...
    I got my Innova last Saturday afternoon... ang pinagawa ko lang ay change ATF and fuel filter...
    so far so good... malaking improvement sa acceleration response... akyatan naman ay hindi na bitin... I have yet to try my old driving habit sa akyatan to really compare... but from initial observations... mukhang malaking improvement...
    ang ipinagtataka ko lang.. nung sa toyota ortigas for 110k pms.. nakalagay sa repair order kasama yung pag inspect ng atf and fuel filters.... mukhang hindi ginawa...
    anyway.. will post further observations in a few days time...
    May 2008
    #651
    Sir DieselDude,
    Wow galing naman! may help desk po pla para sa diesel fuel inj system.
    ask ko lang po sir kung yung 4D56 TDIC ng '95 Pajero is of Direct Injection or an in-direct injection system?
    I mean, direkta po ba na nag i-inject ng fuel yung injectors nya sa loob ng cylinders or may some sort of pre combustion chamber po sya?
    And ilan po ang recommended running hours ng injectors and injection pump para ipa service / calibrate?
    and regarding po sa turbocharger, kelangan po ba talaga na hwag muna i-off yung makina after ng byahe. hayaan lang na naka idle for atleast 5 minutes para hwag kagad masira yung turbocharger?
    Slamat po ng marami in advance
    sensya napo. dami tanong.. hehe..
    Dec 2007
    #652
    Quote Originally Posted by wowiesy View Post
    Good to hear about the positive result on your car. I've been keenly following your progress on this thread as I also have a D4D Innova. Makes sense on the transmission fluid. Have you had it changed before and when? Siguro yung checking na ginawa sa toyota Ortigas ay simpleng level check. I don't think they have the capability to check the quality of the transmission fluid. If it is due for changing then they should have changed it already. Yung fuel filters naman, when was the last time you had it changed? Mine kasi was changed today at 15K km PMS. If I remember it correctly, it was changed on my 5K km PMS. Kanina when I inspected the old filter, maraming ng dumi. Touota service technician recommends a filter change every 5K km. It also makes sense na kapag barado ang fuel filter mo, mahina ang hatak kasi the engine has less fuel to work with. Goodluck.
    Sep 2006
    #653
    Sir DieselDude,
    ask ko lang po sir kung yung 4D56 TDIC ng '95 Pajero is of Direct Injection or an in-direct injection system? Indirect injection ito.
    I mean, direkta po ba na nag i-inject ng fuel yung injectors nya sa loob ng cylinders or may some sort of pre combustion chamber po sya? Meron sha pre-combustion chamber.
    And ilan po ang recommended running hours ng injectors and injection pump para ipa service / calibrate? Wala naman talaga..... but a good practice would be during an engine overhaul. Ipacalibrate mo kung meron lang problema....
    and regarding po sa turbocharger, kelangan po ba talaga na hwag muna i-off yung makina after ng byahe. hayaan lang na naka idle for atleast 5 minutes para hwag kagad masira yung turbocharger? Hindi na kailangan ang 5 minutes cool down kung cruising ang driving style mo like in metro Manila or even slex or nlex. But after a long uphill climb like going up to Baguio, magandang practice ang 5 minutes cool down ng turbo.
    Hindi nag install ng cool down timer ang mga engine maufacturers sa new cars, at hindi naman nagsisisira amg mga turbo nila. D Ba?
    sensya napo. dami tanong.. hehe.. You're welcome.
    Sep 2006
    #654
    You probably had a blocked fuel filter. Tama si Timo07. The best approach to a repair is "basic things first" or "easiest to hardest". This will save you a lot of time and money.
    #655
    update ko lang po regarding sa observations ko so far ...
    noong Monday I observed na mukhang okay na sya... sa basement parking namin, as well as the NLEX...
    however, yesterday (Tuesday) along NLEX.. I noticed na parang hirap pa rin sya mag accelerate.. I am not sure if this is due to my adjustments sa driving habits ko .. sa basement parking naman namin ay ok pa rin...
    will observe further pa...
    incidentally, I also got a call from Toyota Ortigas asking about dun sa works na ginawa nila.. I said flatly na I sent it to another outlet for a 2nd opinion and right now still under observation...
    Sep 2006
    #656
    noong Monday I observed na mukhang okay na sya... sa basement parking namin, as well as the NLEX... Very good...
    however, yesterday (Tuesday) along NLEX.. I noticed na parang hirap pa rin sya mag accelerate.. I am not sure if this is due to my adjustments sa driving habits ko .. sa basement parking naman namin ay ok pa rin... will observe further pa... This is very subjective and will be difficult to evaluate as even you are not sure if it is due to your driving habits. Best way is to have your car tested on a chassis dynamometer to see if vehicle performance conforms to Toyota specs. The test will cost you though.
    incidentally, I also got a call from Toyota Ortigas asking about dun sa works na ginawa nila.. I said flatly na I sent it to another outlet for a 2nd opinion and right now still under observation... Good...
    #657
    now that the Innova has been with me for about a week from the last change of ATF / fuel filter... pati sa basement parking paakyat medyo nahihirapan na sya... even on EDSA last night pauwi... naobserve ko na may times na nabigla hindi sya maka accelerate ... not sure if this is more of a transmission issue or sa engine issue..
    Sep 2006
    #658
    now that the Innova has been with me for about a week from the last change of ATF / fuel filter... pati sa basement parking paakyat medyo nahihirapan na sya... even on EDSA last night pauwi... naobserve ko na may times na bigla hindi sya maka accelerate ... not sure if this is more of a transmission issue or sa engine issue..
    This is probably a supply pump problem.
    Dec 2008
    #659
    Same with my RVR 4d68 when it suddenly lost power during acceleration & uphill. Problem was it was just overhauled & calibrated 2 months ago at Rapide (wrong choice!!!). Brought it back to them, checked the injection pump, diagnosis was a worn automatic transmission. Brought to to Banawe have my transmission checked by Baltak however they were not convinced it was a transmission problem, change my ATF. Fuel filter changed still no avail, turbo changed still no avail, they then told me that it was the injection pump. Returned to Rapide to have my injection pump checked again. After checks & adjustments still no avail & insisted that it was the transmission. Returned to Baltak (Rapide is 2x expensive!) for transmission change, checked it again still not convinced & brought me to denso. Denso told me "sakal" ang injection pump tried some adjustments and certain that it was the culprit, called Rapide told them of Denso however they insisted the transmission. Denso brought down the injection pump, culprit clogged due to worn rubber probably improperly installed! Recalibration also done-problem solved!
    Dec 2008
    #660
Diesel Fuel Injection System Help Desk
