Dieseldude need your expert advice about my subic pajero 4m40.
Subic 4M40s come in two injection pump versions, regular rotary mechanical pump or elctronic COVEC F pump. Which one do you have? -It's electronic sir .
1. Ang lakas sa oil almost 1 liter every week. Wala naman leak.
2. Hard starting sa morning and everytime na i park siya, kailangan i pump yung fuel para mag start. Sometimes maraming beses pa rin na try bago mag start, kahit pump mo pa yung diesel.
3. Laging namamtayan ng makina kahit nasa rekta, then pump muna ulit bago mag start.
4. Eratic Idling
5. Nung last cleaning ng fuel lines and fuel tank pansin namin na madumi parang may halong langis yung tank.
6.As of my last reading 4.9 km/liter fuel consumption ko.
Your complaints seem to indicate an injection pump failure. But first check your glow plugs and glow plug relay. If these are ok, your injection pump may be faulty.- I will ask my local mechanic to check everything first before i let them pull down the injector including the fuel lines for leaks.
I'm from Tacloban City leyte if ever pwede ko ba padala jan yung injector kung kailangan ng i calibrate then ship niyo nalang ulit pag nagawa na? How much po charge niyo estimate para maayos ko yung budget? Ilang days po matapos?
Rough estimate is 6 to 9k for the injection pump. Work duration is 1 to 2 days.- pls text me the address heres my number 09283140707
