Page 57 of 62 FirstFirst ... 747535455565758596061 ... LastLast
Results 1,121 to 1,140 of 1227
    Quote Originally Posted by Miles_on View Post
    Konti lang naman ata price difference between the OEM Mitsu. oil filter and these aftermarket brands.
    What's so good about them that parang mas preferred pa gamitin over OEM minsan?
    Just asking lang naman, because maybe there's something you guys know na hindi ko nakikita, so kindly share.
    My take kasi is air, fuel and oil filters are critical engine components, so I stick with OEM because sigurado 100% up to design spec sila (as long as hindi fake/imitation yung nabili of course), even if compared to reputable aftermarket brands like Vic, Wix, Fleetman, etc.
    See reply of sir testament. Filtration ability kasi mahalaga at proven kasi by actual independent tests specially in the US na maraming used oil analysis shop.
    Ano name nun nagbebenta ng balbwin oil filter na taga QC or doon sa malapit sa lechonan?
    Jan 2016
    #1123
    I think sya si SamJuans shop?
    Mar 2018
    #1124
    In FB,.look for Zic Baldwin. Before ang meeting place nya is sa liempo store on the side of SM Mezza.
    Sent from my M2012K11AG using Tsikot Forums mobile app
    #1125
    Twice na ako nakabili ng baldwin B33 oil filter sa Lazada, tumaas na lumipat muna ako sa Wix WL7572 mas mura.
    Feb 2014
    #1126
    wixeurope website lists the 7119 as the filter for the jimny jb74 but i can't find it anymore
    what's the risk of using a similarly sized one like the 7131 ?
    Quote Originally Posted by Vodka View Post
    7119 seems to be smaller so it can't handle contaminants as much as 7131. Fitment is the only issue imho. If it fits, okay yan.
    BD28 din ideal sa L200 pick-up ko noon but BD7028 its big brother can also be used. No issue. Fitment lang talaga kasi nga taller ang BD7028 vs BD28
    Feb 2014
    #1128
    yeah 7119 is really tiny (exact same size as original suzuki filter)
    they only differ in the "H" dimension (height) so i have to check if there's enough clearance coz it's right above the front axle
    you think the differences in spring rate of the bypass valves will be a problem?
    Nope, won't be a problem. Same lang sila halos ng bypass valve setting.
    Coralfly Diesel Engine Filters Wl7154 Wl7134 Wl7131 Wl7119 Wl7171 51334 Wl72 43 Wl7172 51348 Fit Wix Oil Filter - China Wix Filter and Wix Oil Filter
    Not the same brand but it seems both models do have same bypass rating, size lang talaga difference. Plus I don't think you would be using it for more than 20,000kms, enough to clog the filter or make the oil so thick so as not to flow that easily anymore. hehe
    Feb 2014
    #1130
    Coralfly Diesel Engine Filters Wl7154 Wl7134 Wl7131 Wl7119 Wl7171 51334 Wl72?? 4??3 Wl7172 51348 Fit Wix Oil Filter - China Wix Filter and Wix Oil Filter
    haha you're right!
    interesting link btw. they seem to be making fake wix filters LOL
    Feb 2014
    #1131
    update! dumating na yung 7131. as expected it's longer but the threaded part isn't recessed like on the 7119
    so probably not safe to substitute
    Jul 2014
    #1132
    Para sa anong sasakyan?
    Sent from my CPH1911 using Tsikot Forums mobile app
    Sep 2021
    #1133
    If you want to experiment with alternative filters...
    --- > maybe it would be a good idea to have a stock one, or one that you're sure will work properly in reserve in the car, just in case?
    --- > I don't know if its possible, but a poorly fitting one may not leak (yet) in the garage, but spring a leak later down the road (kasi under pressure/load na). Imagine realizing you're losing oil pala and nasa malayo kang lugar...
    Baka mahaba masyado bolt at sumayad. Pwede naman itry.
    Sa 4m40 Pajero ko I tried BD28 and hindi pwede kasi may sumasabit sa loob. Mahaba yung bolt ng 4M40 kaya BD7028 talaga. Unlike sa 4d56T na Strada na pwede kahit BD28 or BD7028.
    Sa case mo baka ganun din, mukhang mahab bolt niyan kasi recessed yung sa 7119, baka sumabit yung 7131.
    Pero try mo lang muna. Kapag pumasok at mahigpitan, okay yan.
    Nov 2017
    #1135
    There seems to be a lack of supply of Motul engine oils. I already inquired at 3 car maintenance shops and they all said there's no Motul.
    Nov 2017
    #1136
    I got the chance to talk to a nearby car mechanic shop. Another distributor snitched the Motul supply from Autoplus.
    #1137
    Bakit madami nagbebenta sa Lazada?
    Sent from my JEF-NX9 using Tsikot Forums mobile app
    Feb 2009
    #1138
    not oil filter related, but has anyone tried installing a neodymium magnet disc on the drain plug or istalled a magnet around the externally installed oil filter? similar to the rear wheel drive differential drain plug, there is a magnetic tip on it to hold and prevent the ferrous particles from moving around
    Hard drive disk magnet nilagay ko sa OCC. Mukhang okay din nga kung around sa oil filter ano.
    Feb 2009
    #1140
    the neodymium disc magnet has low profile and comes in sizes that is the same diameter as the tip of the drain plug. neodymium magnets are very strong and can hold more particles. on outboard mounted filters, i use a magnetic strip similar to those found on refrigerator door magnetic seal. i staple both ends once fitted around the circumference of the filter housing
Best Oil/Fuel Filters
