Page 59 of 62 FirstFirst ... 9495556575859606162 LastLast
Results 1,161 to 1,180 of 1227
    #1161
    What's so special with SUVs? Pwede din naman siguro itong Shell Helix engine oil sa sedan as long as matched naman yung oil grade like API SN (or the newer SP)
    Attachment 45757Attachment 45758
    "marketing".
    if sedans and hatchbacks were vastly more popular than SUVs, i am confident the etiketa would have run, "for sedan and hatchback engines..."
    and if warming up the engine in the garage were the standard practice, it would probably run, "best for warming up the engine in the garage..."
    the change in etiketa lyrics cost them practically nothing.
    heh heh heh.
    i use cheap ordinary mineral oil, replacing it regularly every 5000 km.
    kumusta ang repsol? parang may nabasa ako dito may nakagamit na ata
    #1163
    I used it for a week in my d40, hindi ako kumportable sa amoy after a long drive..parang nasusunog ang amoy ng makina
    Sent from my SM-A525F using Tsikot Forums mobile app
    Mar 2024
    #1164
    Comparing regular mineral oil vs Amsoil signature series on my 2gd hilux. Ramdam na mas tahimik at less vibration ng makina at mid rpm acceleration. Gastos ng mas malaki pero worth it naman siguro because I can change my oil 7,000 km to 10, 000km reading on Amsoil sig series compared to mineral na need palitan every 5, 000km.
    Sent from my SM-S916B using Tsikot Forums mobile app
    Jan 2016
    #1165
    Quote Originally Posted by 3gems01 View Post
    Lalo na kung tulad dito sa amin na 600 ang labor ng OC
    Mar 2024
    #1166
    Plus yung oras gugulon mo.
    Delo gold 15w30
    230pesos/liter= 1,840pesos for 8 liters
    Labor
    Change oil every 5, 000
    1840x2=3680
    Labor 600 x2 =1200
    Total: 4880pesos
    700pesos/liter= 5,600pesos for 8 liters
    Labor 600
    Change oil every 10, 000km
    Total: 6,200
    Halos 1500 pesos lang difference sa isang change oil fully synthetic vs mineral oil dalawang balik sa mekaniko at 10,000 km reading. Mag fully synthetic nalang ako pasok pa sa required oil ng 2gd engine plus mas fuel efficient pa makina on fully synthetic.
    Dec 2023
    #1167
    Delo gold 15w30
    Labor
    1840x2=3680
    Labor 600 x2 =1200
    Total: 4880pesos
    Labor 600
    Total: 6,200
    Mas magandang 5000km to 8000km max ang oil change. Full Synthetic 10000km is bad practice. Also mukhang mas maganda Shell LD5 oil kaysa delo around P300 naka API CK.
    Aug 2017
    #1168
    Anyone ever used the new brands on the market with advertised "for extended drain intervals" like K&N Select? Nakasulat sa box good for 20,000 miles or 32,000km, but the filtration efficiency is not really mentioned anywhere.
    I prefer good filtration over extended drain filters--maybe except when its a Fram Ultra (I use a Fram Ultra XG3614 on my fortuner for 30,000km before changing the filter coupled with 10k oil changes).
    I also run Isuzu's genuine filter (8981650710) on a D-max for 20,000km with 10k oil changes. 20k oil filter changes are listed in the manual so I followed it without ill effects, cut open my oil filters too and found nothing abnormal.
    Remember oil filters get more efficient over time. Sayang sa pera yung 5k oil filter changes kung malinis makina mo. Cut open your oil filters to help make your decision. I have an oil filter cutter for this hehe.
    Quote Originally Posted by DiWong View Post
    Depends on the driving factors. If its everyday 3 hour metro manila traffic sure. But If its mixed driving with some highway miles in it then there's nothing wrong with going 10k or even 15k if you're using a quality full synthetic like amsoil/zic etc. Also if your vehicle has a bigger sump (like 7liters for your usual diesel SUV/trucks) then it can easily go farther than 10k, sobrang conservative lang ng estimate ng 10k oil change interval dito sa pinas since it already includes the traffic/severe driving factor in it--otherwise we would be following the euro oil change intervals which is 20k or 2 years.
    Jul 2014
    #1169
    [QUOTE=leoblack9;3380721]
    Saan ka nakabili ng filter cutter?
    Nov 2019
    #1170
    Quote Originally Posted by leoblack9 View Post
    Ako nga, I am still following the 6 mos interval sa CASA.
    8 mos nga ako bumisita for the PMS kahit less than 3k lang tinakbo.
    Needed dahil warranty pa.
    Jan 2009
    #1171
    I'm after engine longevity so I change the oil and oil filter as recommended for Diesels. Diesel engines are anything but clean.
    Right now driving a new car with a 1GD engine, I still follow the 4-6 months or 5k km OCI for the free PMS until it reaches 20k. I'm just using the Toyota 15W40 mineral oil. The engine is happy and quiet. Once the free PMS is up, I'm going to continue with a 6-month or 6-8k km OCI using Amsoil 5w-40.
    I've stopped using Zic (used both X7 and X7000 Diesel engine oils) as my experience with it in my previous 2KD is that, the engine starts to clatter noticeably louder after just a couple of weeks on the new oil. This may indicate that its anti-shear properties are not that great. Granted, the 2KD isn't exactly a quiet engine to start with compared to modern Diesel engines, so take this with a grain of salt.
    Quote Originally Posted by carxynogen View Post
    If under warranty wise decision talaga na sundin ang nasa manual. After three years pwede na yung gusto mo hehe.
    Aug 2017
    #1173
    [QUOTE=Mask Rider Blac;3380730]
    Lazada it's just 600 to 800 there depende sa sale or coupon mo.
    Jul 2014
    #1174
    [QUOTE=leoblack9;3380750]
    Quote Originally Posted by Mask Rider Blac View Post
    Thanks! Added to cart
    Jul 2014
    #1175
    Na-curious ako kaya nag-google, may ganito palang article:
    Shell Lubricants introduces expert oil analysis service to the Philippines' fastest-growing industries | About us
    Jul 2014
    #1176
    Kung every other week ang oil change *10K kms, changed to every 20K kms, so every month ang palit..$$
    Aug 2017
    #1177
    pag large capacity sumps chicken lang yan sa mga trucks or busses. Pag May oil analysis ka it's not unheard of truck companies running their rigs upto 40,000km. 20-30L ba naman yung size ng oil sump ng mga yan.
    Para sating private vehicle owners naman May factor din yung sump size. Pag 7L sump diesel chicken lang ang annual oil change na 10,000km. Pag mga small cars na May 3 or 4 liter sumps dyan ako susunod sa 6mos or 5k rule, mas mabilis madeplete ang additives sa smaller sumps.
    #1178
    ... personally, i don't see how...
    Jan 2009
    #1179
    [QUOTE=dr. d;3380759]
    He meant to say, efficient at filtering. A bit of crud catches more crud at the expense of flow rate. But for as long as the flow rate does not go below what the engine requires, it should be fine.
    But if you go beyond the filter's dirt-bearing capacity and clog up the filter media, it will open up the bypass valve (if equipped), allowing unfiltered oil to bypass the filter and circulated back into the engine.
    #1180
    [QUOTE=oj88;3380763]
    well,
    it's not really my definition of "efficiency".
    more like "poisoning".
Best Oil/Fuel Filters
