BT223 3
Sent from my CPH1911 using Tsikot Forums mobile app
Baldwin B2 side-by-side
Made in U.S.A / Made in Morocco
Baldwin B1402
Made in Morocco
Baldwin B7172 side-by-side
Made in U.S.A. / Made in K.S.A.
The only obvious difference is the print "Made in _____"
Just from the posted Baldwin pictures, mukhang mas well made pa yung mga non-Made in USA?
Yun nga bang Baldwin BT223 ang compatible sa Toyota Altis 9th gen?
So far I've tried Baldwin and Donaldson, plus yung Toyota na pang-Camry sa Altis 2003 ko.
Para sa akin, kahit may differences, parang pareho lang ang quality. Gusto ko sanang buksan pero wala pa ako sa ganung level hehe
For the Altis na canister type ang oil filter, ¾-16 ang thread size, so pwede ang BT223. Pwede rin B1405. Longer filters: B7172, B113, B243, B1416, B178.
For the Altis na elemet type ang oil filter (Toyota 4152-YZZA6), pwde Baldwin P7454..I think this is Made either in Taiwan or Korea.
Baldwin B33 side-by-side
Made in U.S.A. / Made in Mexico
Difference:
1) website;
2) "a CLARCOR company"
Difference:
3) Made in Mexico has crimps;
4) Made in Mexico has smaller font size;
5) Made in Mexico has sharper characters/text
Difference:
6) Made in U.S.A. has 11-digit manufacturing reference code)
7) Made in Mexico has 6-digit manufacturing reference code
Yes. As far as I know, BT223, B1402, B2 are now made in Morocco. B33 made in Mexico. BF1280 made in China. All these filters used to be made in US. Local importers have difficulty sourcing BT223 and B37. Donaldson P502008 in now made in Colombia..used to be made in Indonesia.
New stocks BT223
Made in USA
Manufacturing date: July 19, 2022
Individual pack/box has new/different design/s. Texture of materials used similar with packs/boxes being used in other areas (i.e., Mexico, Morocco)
The filter itself is still the same.
if it's ok to use non-oem engine oil filters on our vehicles, does it follow that using replacement atf transmission filters would pose no problems too?
Canister filters are usually pre-oiled from the factory. There are times when packaging is damaged and the filter is exposed to heat, moisture, etc. Below is a 2020 filter with damaged shrink wrap, dust on the rubber gasket, and rust.
