Results 51 to 60 of 193
July 11th, 2013 10:55 PM #51
- Jul 2010
- 844
July 11th, 2013 11:01 PM #52
- Nov 2009
- 3,507
July 11th, 2013 11:02 PM #53^ Could be if shorted. In actual, usually lower than terminal voltage and not enough juice (current).
July 11th, 2013 11:06 PM #54
ginagamit ko rin yung welding cables ko na 50 sq. mm sa jump starting. crimped connections with minimal soldering.
July 11th, 2013 11:07 PM #55
Kaya ko naman natanong yan sir, kasi kung meron pang 10v sa dead battery, hindi siya resistive load kasi source pa din yan.
July 11th, 2013 11:14 PM #56
dead --- battery na di kaya mag start ng makina
dead can mean naubos lang ang karga pero di sira ang battery (like naiwan naka on ang ilaw or nag boom-boom sounds habang naka patay ang makina)
dead can also mean sira na talaga ang battery (di na tumatanggap ng karga or tumatanggap pa ng karga pero storage doesnt last)
July 11th, 2013 11:19 PM #57
parallel -- positive sa positive negative sa negative
2 12v battery total out 12v parin
kahit sampung battery pa yan basta lahat ng positive magkasama lahal ng negative magkasama
series -- parang FLASHLIGHT!
positive to negative to positive to negative
2 12v battery total out 24v
kung 3 battery total out 36v and so on
July 11th, 2013 11:21 PM #58
July 11th, 2013 11:22 PM #59
Kung dead na talaga baterya as in 0v then it could be considered as resistive load hence, series ang circuit mo. But kung dead ang baterya pero may e.g. 10v pa then parallel ang connection mo kasi source pa din yan kahit depleted.
July 11th, 2013 11:26 PM #60
kung ang flashlight mo 3 D-battery tapos isa sa tatlong battery ay patay na iilaw parin ang bulb pero mahina
yan ang point mo
The Yokohama BluEarths notoriously break down as you use them. I guess something in their...
Finding the Best Tire for You
