Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 193
    Patay ka din sa hazmat jung hydrogen bomb este hydrogen buildup sa battery.
    Eto proper suit for handling battery.
    Ala eh kesa bumile ako nire... bibili na lang ako ng bagong baterya.
    Retz, seriously? :rofl:
    Pinost na ni uls yung proper attire pag gagamit ka ng jumper cable
    Sent from my GT-N7100 using Tapatalk 4 Beta
    yung hazmat suit?
    haha that was a joke... pero kung gusto mo pwede din
    yung hazmat suit?
    Of course I know :bwahaha:
    you sounded serious hehe
    eto ang ginagamit namin power source
    2 4D naka-push cart
    As a general rule based fron nabasa ko - gauge 6 for small cars, extending the length increases the resistance so u have to increase the gauge, the bigger/shorter the better.
    based kasi lahat sa "nabasa". pwede naman subukan muna.
    Kailangan pa bang mag suot ng jumper suit habang nag jujumper?
    oo, tapos properly insulated shoes and rubber gloves. o ya don't forget mask, pero kung wala, pwede rin helmet na full face na with proper padding.
    Quote Originally Posted by [archie] View Post
    Subukan niyo na rin ito:
    Pasado sa lahat ng klase ng National, International, Universal at Inasal Standards kasama pati
    ANSI standards + ISO, IEC, DIN ASTM, ASHRAE, INCITS, NFPA & more... :hysterical:
    Tama ginawa ko. I followed the video step by step e.
    ya you followed step by step procedure nga but you didnt achieve the objective which is starting the car
    Oct 2011
    napaayos na ba ang baterya ni cat?
    kasi kulang ground...
    i'm usually not in a hurry to start the car.
    when i bought an AT car, i also bought a battery charger. yes, i also have a set of jumpers. but i still prefer the charger. less hassle than the jumpers..
    ya that's what i do at home when the car wont start in the morning coz of weak battery
    i charge the battery nalang without removing the battery from the car
    15 minutes lang naman
    di bale ma-late konte hehe
    cdr king meron. 1200 or 1400 ata kuha ko. yung kulay green na may clamp. may flashlight pa
    Jun 2012
    Sa susunod na balik mo baka may tow truck na.
    Oct 2011
    hindi kaya mabilis masira yan sir?
    Kaya pala nagmahal dahil nakaclamp na siya. Dati parang 120 - 140 petot lang, paper clip nga lang yung dulo
    Sent from my GT-I9300 using Tapatalk 4 Beta
    just last night, i jump-started my diesel innova. i used the cheapest cables i could find in xxxxmart. 400 amp daw sa cover (pmpo, most probably, because the cables obviously were not thick enough. heh heh). my power source was my other diesel innova on idling. i succeeded. the cables didn't even get warm. but then, it was a single click operation..
    maybe if the first car refuses to cooperate and we have to try several times, something would have warmed up considerably.
    so, i suppose if it's just a simple matter of jump-starting an otherwise perfectly good car, then the cheap mall-sourced cables are fine..
    and unless it's a sherman tank, it can probably be push-started even easier..
    (btw, sherman tanks used gasoline engines! when a shell hit, the gas burned, killing everyone inside..)
    antay nga ako shop crane. hindi malayo magkaroon cdr king.
Jumper cable amp rating
