Page 8 of 10 FirstFirst ... 45678910 LastLast
Results 141 to 160 of 193
    you sounded serious hehe
    eto ang ginagamit namin power source
    2 4D naka-push cart
    #143
    Patay ka din sa hazmat jung hydrogen bomb este hydrogen buildup sa battery.
    Eto proper suit for handling battery.
    Ala eh kesa bumile ako nire... bibili na lang ako ng bagong baterya.
    #144
    wala naman pumipilit sa inyo mag neg terminal to neg terminal
    use body ground all you want
    like cathy did. she followed step by step instructions pero di niya na-start car niya. may nagsabi tuloy stuck-up na makina niya
    pero napaandar niya noong pinalitan niya ng battery
    so what went wrong?
    suspetcha ko body ground. mali location pagkalagay ng cathy. kung nilagay niya sa neg terminal umandar sana yan
    in those few seconds kukulo ba ang battery acid at magrelease ng vapor? i doubt it
    Suspetsa ko pa dyan nakajumpsuite si cathy nun nilagay, sa altis yata naitap ung negative hindi sa rola.
    Sent from my GT-I9300 using Tapatalk 4 Beta
    Tama ginawa ko. I followed the video step by step e.
    Sent from my GT-N7100 using Tapatalk 4 Beta
    ya you followed step by step procedure nga but you didnt achieve the objective which is starting the car
    Oct 2011
    #147
    napaayos na ba ang baterya ni cat?
    #148
    kasi kulang ground...
    #149
    i'm usually not in a hurry to start the car.
    when i bought an AT car, i also bought a battery charger. yes, i also have a set of jumpers. but i still prefer the charger. less hassle than the jumpers..
    ya that's what i do at home when the car wont start in the morning coz of weak battery
    i charge the battery nalang without removing the battery from the car
    15 minutes lang naman
    di bale ma-late konte hehe
    #151
    Sorry kung makulit. Saan at how much ka nakabili ng battery charger mo bro uls? Makabili na nga rin for emergency purposes.
    Quote Originally Posted by beni23 View Post
    you can buy battery charger at your friendly neighborhood electrical/hardware
    price will depend on capacity
    P1000 up to several thousands
    pwede na yung under P3000
    #153
    cdr king meron. 1200 or 1400 ata kuha ko. yung kulay green na may clamp. may flashlight pa
    #154
    Quote Originally Posted by [archie] View Post
    Kaya pala nagmahal dahil nakaclamp na siya. Dati parang 120 - 140 petot lang, paper clip nga lang yung dulo
    #155
    just last night, i jump-started my diesel innova. i used the cheapest cables i could find in xxxxmart. 400 amp daw sa cover (pmpo, most probably, because the cables obviously were not thick enough. heh heh). my power source was my other diesel innova on idling. i succeeded. the cables didn't even get warm. but then, it was a single click operation..
    maybe if the first car refuses to cooperate and we have to try several times, something would have warmed up considerably.
    so, i suppose if it's just a simple matter of jump-starting an otherwise perfectly good car, then the cheap mall-sourced cables are fine..
    and unless it's a sherman tank, it can probably be push-started even easier..
    (btw, sherman tanks used gasoline engines! when a shell hit, the gas burned, killing everyone inside..)
    Jun 2012
    #156
    Sa susunod na balik mo baka may tow truck na.
    #157
    antay nga ako shop crane. hindi malayo magkaroon cdr king.
    Jun 2012
    #158
    Hehe, wag lang sila magtinda ng eroplano.
    Oct 2011
    #159
    hindi kaya mabilis masira yan sir?
    #160
    not sure on durability pero mga 2 months ko na gamit pang testing ng sounds and electrical. ok pa naman. A full charge last around 2 days with moderate to heavy use. worth it na kung tumagal ng 1 year.
Jumper cable amp rating
