Results 151 to 160 of 193
July 17th, 2013 12:12 AM #151
July 17th, 2013 12:21 AM #152
July 17th, 2013 04:57 AM #153
cdr king meron. 1200 or 1400 ata kuha ko. yung kulay green na may clamp. may flashlight pa
July 17th, 2013 05:04 AM #154
- 52,731
July 20th, 2013 07:37 PM #155just last night, i jump-started my diesel innova. i used the cheapest cables i could find in xxxxmart. 400 amp daw sa cover (pmpo, most probably, because the cables obviously were not thick enough. heh heh). my power source was my other diesel innova on idling. i succeeded. the cables didn't even get warm. but then, it was a single click operation..
maybe if the first car refuses to cooperate and we have to try several times, something would have warmed up considerably.
so, i suppose if it's just a simple matter of jump-starting an otherwise perfectly good car, then the cheap mall-sourced cables are fine..
and unless it's a sherman tank, it can probably be push-started even easier..
(btw, sherman tanks used gasoline engines! when a shell hit, the gas burned, killing everyone inside..)Last edited by dr. d; July 20th, 2013 at 07:55 PM.
July 21st, 2013 09:53 AM #156
July 22nd, 2013 10:05 AM #158
July 22nd, 2013 04:09 PM #160
not sure on durability pero mga 2 months ko na gamit pang testing ng sounds and electrical. ok pa naman. A full charge last around 2 days with moderate to heavy use. worth it na kung tumagal ng 1 year.
Xiaomi E-Car
