Results 2,061 to 2,070 of 2282
May 9th, 2021 10:04 PM #2061
- Mar 2021
- 636
May 9th, 2021 10:14 PM #2062Yung Amaron ko sa daily driver lasted 23 months only. 2 months after ng warranty.
Then switched to Panasonic that lasted 35 months. Replaced with another Panasonic. [emoji4] at sana umabot ng 35months din
- 54,215
May 9th, 2021 11:51 PM #2063
May 10th, 2021 12:57 AM #2064
May 10th, 2021 09:24 AM #2065
Is there a difference between gas or diesel engine in the life span of the battery? Because diesel requires more amps during startup and might cause the battery to deteriorate more compared to gas.
May 10th, 2021 11:08 AM #2066
Iirc mas demanding ang diesel cars kaya mas tumatagal talaga battery with gas fed engines. Diesel cars need more oomph to power the cranks as they are compression type.
Sent from my SM-N960F using Tsikot Forums mobile appFasten your seatbelt! Or else...Driven To Thrill!
May 10th, 2021 12:30 PM #2067
May 10th, 2021 02:18 PM #2068
Guys I don't really fancy posting about work so let me start and end with this. Energizer has only been in the market for 2+ years. Too early to tell if it will perform better or worse than Amaron. And yes it was under the same company as Amaron's past technical partner, Johnson Controls (now Clarios). Varta and Optima were under JC in the past as well. Main differentiator would be the EFB and AGM batteries. Standard start/stop cars require EFBs. Those with regenerative braking and/or luxury makes usually require AGMs.
- 54,215
May 10th, 2021 07:07 PM #2069
May 10th, 2021 08:39 PM #2070
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
