Results 2,091 to 2,100 of 2282
July 18th, 2021 12:18 AM #2091
July 18th, 2021 12:32 AM #2092
- Jul 2009
- 2,618
July 25th, 2021 07:12 PM #2093mga ka-tsikot ask ko lang. 2015 fortuner MT 2kd-ftv. stock wala naman ako accessories na power hungry like a killer sound system.
worth it ba mag 3sm pa na battery or balik 2sm uli from the factory? amaron pa din. libo din kasi price difference. salamat
July 25th, 2021 07:46 PM #2094
July 25th, 2021 07:53 PM #2095
If the stock battery is 2SM, you'll be fine with a replacement 2SM. Practical advantage lang ng 3SM is the bigger reserve capacity and cranking Amps. Depending on actual use, the additional capacity may offer some insurance in starting the engine even if an accessory was left on overnight, for example, or if you run into an engine issue that requires you to crank it longer than usual.
It's up to you if you feel that the extra capacity is worth its weight (literally) in Pesos.
FWIW, I have a 3SM Amaron in my 2.5 Innova G.Last edited by oj88; July 25th, 2021 at 07:56 PM.
- 54,206
July 25th, 2021 09:26 PM #2096issue with installing larger battery: kakasya ba? will the battery footprint be accomodated? will there be enough room above, so's the metal hood won't touch the terminals?
will a larger battery result to longer battery life in that vehicle? i do not know.
the larger CCA might result in chronic under-charging, which predisposes to faster battery deterioration.
i do not know.
in my non-diesel sedan with only a stock radio as electrical toy,
i install the next smaller size battery.
over the years, i did not perceive a shorter lifespan.Last edited by dr. d; July 25th, 2021 at 09:44 PM.
- Mar 2021
- 636
July 25th, 2021 09:36 PM #2097
July 25th, 2021 09:41 PM #2098
I would just stick with using the same battery size
Unless there is no stock of the correct battery and there is no choice
- Jan 2007
- 2,587
July 26th, 2021 03:27 AM #2099From what I understand naka 3SM na ata si babkalakal ngayon, so it will definitely fit, and the alternator is definitely capable of charging a 3SM battery.
His question is if it's worth it to continue using a 3SM or go back down to stock size of 2SM.
If the car is frequently used, there are no accessories with big power draw, and accessories aren't operated on battery for extended periods I vote to save the money and size back down.
- 54,206
July 26th, 2021 08:41 AM #2100
San mo nabili?
Fire Extinguisher for Car: what brand and type...
