Page 17 of 38 FirstFirst ... 713141516171819202127 ... LastLast
Results 321 to 340 of 758
    #321
    magkano ang price range ng matitinong GPS?
    Sep 2005
    #322
    Quote Originally Posted by j_avonni View Post
    I'm still testing the GPS in my Nokia E90.
    I'd appreciate for any tips or suggestions.
    :car: [SIZE=1]4164[/SIZE]
    The E90 was Nokia's 2nd phone with a built-in GPS receiver after the N95. The E90's operating system, processor and receiver chipset are also the same as the N95's ... so GPS-wise, any remark regarding the N95 within the thread should be applicable to the E90.
    Remember to stay still in the clear when you're trying to get a first fix (GPS receiver trying to synchcronize with the GPS satellite signal).
    Get the Garmin app and the freewebs Philippine map.
    Jun 2005
    #323
    Quote Originally Posted by StraightSix View Post
    Thanks a lot StraightSix.
    :car: [SIZE="1"]4166[/SIZE]
    May 2007
    #324
    share ko lang...
    just got a Garmin Nuvi Gps and i'm loving it! will put it to test when we travel to Mimosa on Saturday.
    May 2007
    #325
    Check this out --->
    http://www.avt.ph/
    #326
    SO what's the SRP for your product?
    #327
    ang gps ba libre dito? gusto ko itry kasi gamit ang 5800xpressmusic ko. just don't know, how to use it
    #328
    GPS features are useless without having a local map of the area you will be using it in. So if you are trying to navigate in Metro Manila, make sure your device has the updated map for Metro Manila.
    If your GPS device doesn't have the map/software, you will need to purchase it and have it installed.
    Sep 2005
    #329
    If you want to test the water first ...
    Install Google Maps. It's free. It can point your location on a sattelite map, and should be able to show you directions from A to B. But without a detailed Google street map for the Philippines your search options are few ... and it's not the turn-by-turn navigation you'd normally find on a GPS navigation systems. Just a list of text directions like which road to take, where to turn to, etc.
    When you're ready (to pay for it ) ... get Garmin Mobile XT. It has one of the best routing algorithms out there, which is a commonly overlooked factor for GPS buyers. You see, it's not as simple as figuring out the shortest route from one point to another ... anybody can do that with a paper map and pen. Rather, t has to give you the best route according to your preferences.
    Although Garmin doesn't have a detailed map for the Philippines, Garmin users here have been using the freewebs map which is the best so far ... and it's free!
    Di ko binebenta Garmin ha? It's just that the others have no map for the Philippines. I prefer using Tomtom and iGO.
    #330
    Google Maps is simply useless in Metro Manila. Not enough detail.
    Sep 2005
    #331
    I did say test the water, not take the plunge.
    If you've got a better suggestion, by all means - it'll be most welcome.
    #332
    I have had Google Maps on my GPS equipped phone and it's nowhere even close to the GPS "experience".
    As for suggesting an alternative GPS application, that is the problem. Not much GPS software out there with Philippine map that you can test without buying it first. Even my Nokia 6110 Navigator's "free" GPS software with Metro Manila map was an outdated version of NAVfone with map that is probably 5 to 8 years out of date, based on the roads NOT on the map. Fortunately for me, I found the software's website where I purchased the latest version of the software & map.
    My Nokia 6110 Navigator uses NAVfone:
    http://www.navfone.com/nokia/navfone_n95.asp
    http://www.asiagis.com.sg/agis2/
    Unfortunately I don't think they have a version for the iPhone.
    #333
    installed google maps kahapon pero gusto magconnect sa gprs! eh may sariling gps naman ang 5800
    Jan 2008
    #334
    ^^Try connecting via WLAN, mas mabilis update ng map data..Mabagal at malaki ang per kilobyte ng GPRS. Im also tryin to figure out how to update navteq..wla sa list ng nokia ang ph.. Ano po ba ma s-suggest nyo na gps software?? btw im using N79
    #335
    Quote Originally Posted by jatcos View Post
    You can try NAVfone. The link is posted in my previous message. Its Symbian S60 compatible as well as Windows Mobile, etc. It works well for my Nokia 6110 Navigator. Hopefully it would work with yours.
    BTW, I suggest installing the software & map into your fone's onboard memory and not the sd-card for performance & stability reasons.
    Dec 2008
    #336
    Sir GH great link thanks! I too also have the 6110, can I ask how much it cost you to get the maps for Pinas? Also how is the charging calculated? via 3G usage?
    Kasi on the website of Navfone from the link you provided earlier it states the following:
    NAVFone Pro is a 100% onboard solution. Since all information is on the city map data and it does not communicate to the mobile network, which means zero operating cost to you!
    NAVFone Pro includes the new GprX? technology for 3G & GSM networks. In supported cities, when you cannot use the GPS (e.g. indoors), GprX? provides an approximate location fix based on the cellular network.
    Sorry po, but Im just a little confused. I just want to make sure I understand the whole solution before trying to download anything
    #337
    Quote Originally Posted by snatchmeister View Post
    GPS uses the US military GPS satellite signals, not your 3G or GPRS signals. In fact you can still use the GPS feature of your 6110 even if you have taken out the simm card.
    The software and map of choice(s) is saved within the phone itself. So when you need to use the GPS navigation software, just launch the application anytime, no worries about needing a data connection because you don't need it.
    GPSX is a feature where supplemental location data is taken from celfone towers. Unfortunately for us, Globe and Smart seems to prefer to keep their celfone tower location data secret. So you can just turn off this feature and rely to pure GPS signals to navigate. The only time you'll have problems navigating via pure GPS is when you are driving through areas with tall buildings like Makati business district. Otherwise, signal strength is decent even when I was driving under the Skyway (signals came from the sides too, not just from directly above). It guided me from some place deep in Alabang back to SSH.
    Price... well, maps are US$25, update of software ... I don't remember. Product activation will require for the phone to send a single international SMS message for the activation code to be sent to your phone directly.
    The site will require you to register your phone before you can begin transaction. It will keep tabs of your downloads.
    Maps available:
    Map of Singapore USD 25.00
    Map of Northern Malaysia USD 25.00
    Map of Central Malaysia USD 25.00
    Map of Southern Malaysia USD 25.00
    Map of Ho Chi Minh City (Vietnam) USD 25.00
    Map of Hanoi (Vietnam) USD 25.00
    Map of Jakarta (Indonesia) USD 25.00
    Map of Surabaya (Indonesia) USD 25.00
    Map of Bandung (Indonesia) USD 18.00
    Map of Bali (Indonesia) USD 25.00
    Map of Yogyakarta (Indonesia) USD18.00
    Map of Metropolitan Manila (Philippines) USD25.00
    Map of Cebu (Philippines) USD 25.00
    Map of Boracay (Philippines) USD 25.00
    Map of Davao (Philippines) USD 25.00
    Dec 2008
    #338
    Maps available:
    Awesome sir GH! Thank you for taking the time to write a full reply
    Sep 2005
    #339
    Did you get your "free" copy of NavFone packaged with your mobile phone?
    I tried following the link for the WM version but in the end it was asking for an activation key by calling them on the phone ... WM6.1 also gave a message that it probably won't run since it was written for an earlier version of WM. And the price puts me off ... $100 for 4 places in the country is a bit stiff.
    Nothing more I can add on the iPhone ... except that because of a clause on its licensing requirements, we may never see a full-blown navigation software for it. I got rid of mine the moment I got my XDA Serra, and I'm glad i did.
    Jan 2009
    #340
    EGPS works with my i780. Using My Location in Google Maps, it was able to tell me my approximate location, based on the nearest cell site. You can't use this to navigate, though and it requires an active GPRS/3G connection for data access.
    Not as practical as when using the built-in GPS receiver, EGPS has very poor accuracy (approx. 500 - 1,000 meters) and the My Location dot in Google Maps only indicates the cell site you're currently associated to. But this just proves that cell sites do provide their coordinates when queried by the phone.
    I turn this on only if satellite acquisition is taking too long... which is seldom.
GPS Navigation System [merged threads]
