Page 55 of 70 FirstFirst ... 54551525354555657585965 ... LastLast
Results 1,081 to 1,100 of 1387
    #1081
    dun sa mga long time users ng HID retrofit, di ba nangingitim yun healights nyo?
    yun nakalagay kasi sa vios noon, parang naluluto sya kaya pinalitan ko ng stock.
    Almost 4 years na retrofit ko on my Mazda 3 - di naman nangitim yung headlights.
    #1082
    ano kaya nangyari doon sa vios ko noon O_o
    dont mind the clearcoat damage hehehe
    para syang cloth na nabuhusan ng kape ;D
    Oct 2003
    #1083
    Most likely di na seal ng mabuti yan kaya pinasok ng dumi.
    #1084
    Mabilis lang yan. Pabukas mo, linis then reseal. Mura lang.
    Jan 2008
    #1085
    Sa kin 2 yrs na din malinis pa. Kahit un kay utol 3yrs na clear pa din un HL
    Sent from my Redmi Note 5 using Tapatalk
    #1086
    Quote Originally Posted by zechs View Post
    sa labas talaga sya bro
    sayang nasa ex ko kasi yun headlight, gusto ko sana subukan ipolish hehehe
    Oct 2003
    #1087
    Kung sa labas yan, then plastic clear coat damage yan. Wet sanding then polish then re-spray clear coat. KASO its not going to be as clear as the original.
    Ganyan ung lumang headlights ko. Naninilaw na. Pinagawa ko doon sa isang nagoffer ng ganyang service. Wetsand then spray ng clear coat. Since naka-retrofit ako, dati clear ung cutoff line. Pero after gawin ung wetsand and clear coat, blurry na ung cutoff nya.
    Dec 2013
    #1088
    Gusto ko iDYI fog lamps ni gen 2 monty. Saan shop pwede bumili ng NHK 3inch with flat cutoff? Any specific link?
    Jun 2016
    #1089
    hi guys,
    Any feedback on the quality install of westcustom re-cah? Thanks.
    Aug 2013
    #1090
    Quote Originally Posted by ealdree View Post
    hi guys,
    If tight budget ka bro might as well go with Xenon, aside from Boss Gary, Redline, Firedrake and Chroma sila na pinaka ok na entry level budget wise.
    Oct 2003
    #1091
    Stock HID of the everest is only 25watts and produces around 2000 lumens. Not really "hid". I believe na-consider lang na hid ito is because of the bulb type which is D8S.
    You can "upgrade" the system by changing to a D3S system. Minor adjustment to the bulb holder then you're good to go. Unfortunately, D3S system is also hard to find. Haha
    I've recently tried changing to LEDs which the seller says is rated at 10000+ lumens. Err..will be demoting it to the high beams na lang.
    So logically, step upgrade na to G5 projectors and osram bulbs
    May 2011
    #1092
    #1093
    Quote Originally Posted by mina_nuka View Post
    i DIY it in the workplace parking area. it has a flat, concrete floor and chest-high wall.
    in the evening, there's very few cars there.
    Jun 2016
    #1094
    Quote Originally Posted by Mak Letran View Post
    Thanks a lot bro Mak.
    Jun 2016
    #1095
    Boss Mak and to all you guys, is it safe to place an LED bulb in a halogen projector? Plan to install bi xenon projector on the hi beam and maintain my halogen projector with LED bulb on the low beam. My car is fortuner 2016 old face. Thanks again
    Aug 2013
    #1096
    safe for you because it'll be brighter but not safe to other motorists
    Aug 2013
    #1097
    Any reviews here on Heartrays D2S bulbs? planning to replace my bulbs, current lifespan of my bulbs is about to expire na =(
    Jun 2016
    #1098
    Thanks again bro Mak. Will it address the issue if I lower down the throw of the low beam projectors during install of the bi-beam projectors?
    Oct 2003
    #1099
    Look at that blue band...
    Updates soon
    Oct 2003
    #1100
    Upgrade done! Replaced the stock hid projectors and bulb into hella G5-EX (with AR coating) and osram CBB (very good combo)
    Wide blue band
    Low beam (WAAAAYYYY better than LED)
    High beam (ungodly haha)
Planning on getting an HID retrofit
