Page 59 of 70 FirstFirst ... 94955565758596061626369 ... LastLast
Results 1,161 to 1,180 of 1387
    Sep 2013
    #1161
    Yung osram nightbreaker plus nga pwede na e maliwanag, 2014 ko pa nabili maliwanag parin
    Oct 2003
    #1162
    Ok naman ung osram nb. Kaso i want ung medyo whitish color kaya cbi and cbb gamit ko.
    *ealdree
    Haha mahal kasi philips; laki ng difference sa price.
    Jun 2016
    #1163
    Quote Originally Posted by zechs View Post
    *ealdree
    Will have my CBB installed in my car this Saturday with denso ballast. If I don’t like the output, I might change it to Philips 85122C1 bulbs.
    Oct 2003
    #1164
    PM me if you dont like the osram cbb. Will buy it from you (if price is right) hehe
    Jun 2016
    #1165
    PM me your offer.
    Oct 2003
    #1166
    Oopps too late. Just ordered haha
    *ealdree
    Did you purchase your CBB with PrimeAutoLamps also? Then got cancelled?
    Let me see if Im not satisfied with the koito q5 + osram cbi combo. Will upgrade that to cbb. Test ko muna.
    Jun 2016
    #1167
    *ealdree
    Yup. I purchased my CBB from PrimeAutoLamps.
    Oct 2003
    #1168
    Out with the old yellowing headlight, in with the new. This is the car that will be demoted to reflectors na lang but with osram night breaker laser.
    Old projectors (koito q5) will be going to the other car paired with osram cbi
    Dec 2013
    #1169
    Ikaw bro mag diy ng retrofit?
    Oct 2019
    #1170
    Close up shot of the projector with AR coating
    *sirkosero
    PM'ed you
    Hi Sir, naka Everest din po ako. I will upgrade my stock projector soon. What is the benefit of AR coated lens?
    I plan to buy kits from Lightwerkz then ipapa-buo ko sa Chroma Lights, kaso wala ako makitang projector from Lightwerkz na AR coated lens.
    TO ALL: Papacheck ko lang itong list ko. Your suggestion inputs are highly appreciated....
    - projector: torn between G5-BRT, G5 EX, or G5 EXL (Lightwerkz recommendation is to get G5-BRT however I am after for long range light output so I think I should get G5 EXL because based sa nabasa ko Headlight Junkies mas long range ang G5 EXL. As per Chroma Lights, all G5 models fits stock shroud of Everest)
    - bulb: Osram 66240 Nightbreaker Laser 4200k
    - ballasts: AMP Hyluxtek HYlux 2A88 35W Canbus Ballasts
    - H11 headlight socket adapters
    * I am still thinking if I add Diode Dynamics RGBW Demon Eyes Pro Series with RGBW controller and Switchback Angel Eyes.
    Thank you!
    Oct 2003
    #1171
    Quote Originally Posted by Geronimo Valino View Post
    Nah. I reverted back to reflectors for that car. Kakabitan ko na lang ng osram night breaker laser which just arrived today.
    Kinuha ko ung koito q5 projectors to be installed sa ibang car.
    Oct 2003
    #1172
    Quote Originally Posted by mb1 View Post
    Thank you!
    Quoting Lightwerks G5-BRT page, it says that the AR coating increases output slightly.
    Quoting TRS naman, AR coating increases light transmission while decreasing bleed resulting in 10% more light and less bleed.
    Cant really comment on those demon or angel eyes. Depends on what look you are aiming for. Ako kasi I always aim for that OEM look.
    If its cheaper for you to get the whole retrofit system sa US, then go ahead. Sayang din ung natipid.
    Buti payag si chroma lights na labor only?
    Oct 2019
    #1173
    I see. AR coated na pala ang G5-BRT.
    Inadvise sa akin na since magpaparetrofit na din ako, isagad ko na with angel and demon eyes. Based sa reviews, Diode Dynamics ang pinaka malakas ng light output even at broad day light. I still have to check if discounted ang price sa Black Friday sale and if not then OEM look lang basta importante ling range ang light output.
    Actually cheaper if parts will come from Lightwerkz and mas okay ang ballasts, plus 5k labor with labor & sealing warranty from Chroma Lights. Si Firedrake and RedLine kasi di payag sa labor only. I did not ask naman sa TheRetrofitShop kasi malamang mahal labor dun.
    Oct 2019
    #1174
    Sir pafeedback naman po ng Osram NB Laser. Yan kasi ung bulb na nirecommend sa akin ng Lightwerkz. 4200k daw para all-weather pero feels like 5000k if I will use Hylux canbus ballasts na 35w.
    Oct 2003
    #1175
    Ung night breaker laser ko is for halogens, not xenon. Hehe.
    And hindi ako fan ng 4200K temps. Although ok ung visibility nya, it would always feel like di ako nagupgrade since on the yellowish side ung light output.
    Kung night breaker laser ang gusto mo, check out the philips xv2. Mas better IMO.
    Jun 2016
    #1176
    Guys help pls. Any shop in the south you will recommend to have this repaired?
    Attached Thumbnails Attached Thumbnails 29a374d0-93b3-4ded-b447-6429d2bef140.jpg
    Jun 2005
    #1177
    Quote Originally Posted by ealdree View Post
    Ano ba sira? Is that even related to the topics of retrofits? Di naman makita ano problem
    Kung body panel issue, try going to talyer that does body repair.
    Sent from my MI MAX 2 using Tapatalk
    Jun 2016
    #1178
    Hi Sir. What brand of ballast did you use for this setup? Thanks.
    What would be a better setup for fortuner 2015? 1) quad setup or 2) stock projectors on low beam, bi-beam projector on hi beam and fog bi-beam retrofit
    #1179
    1. Para malayo bato. Mas mataas sa car yun ilaw = better
    Jun 2016
    #1180
    Thanks bro.
Planning on getting an HID retrofit
