Results 311 to 320 of 1387
September 20th, 2017 06:28 PM #311
Pansin ko din yan sa gen5 bolt on ko noon, kahit anong brand ng ballast na china walang difference. Pero nun nilagyan ko ng philips 85122, kita talaga improvement kumpara sa chinese d2s bulbs. Kaya gamitin ko na lang ulit un philips ko sa q5 pag nagpakabit ako kay paolo. Un ballast tama na un hi arc.
Sent from my R7plusf using Tapatalk
September 20th, 2017 07:22 PM #312
kung bulb ang pag uusapan iba talaga ang gawa ng philips or osram if compare mo sa mga chinese made bulbs not to mention high UV of cheap chinese hid bulbs . Kahit ang mga morimoto bulbs ay pwede makipag sabayan sa intensity ng philips at at osram pero sa longevity naman tagilid ang morimoto bulbs.
September 20th, 2017 07:39 PM #313
Was supposed to get Philips bulbs for my Mazda 3 but si Tots na mismo nagsabi na hindi malaki difference sa regular NHK bulbs niya for my Q5 setup.
September 20th, 2017 10:52 PM #315
Nasa magkano ba ang osram d2s bulbs?
- Mar 2014
- 89
September 21st, 2017 02:11 AM #316Here's a quick comparison of garyq's stage 1 Hid projector vs Subaru's Oem LED projector. Both do have a clean cut off but there's a big difference on the light intensity.
Hid
Led
- Oct 2015
- 74
September 21st, 2017 02:23 AM #317
September 21st, 2017 03:00 AM #318
September 21st, 2017 05:18 AM #319
yes tama po observation nyo sa projector test ng lightwerkz kahit ako nag taka din pero sa mga realworld output shot sa headlight junkies fb group d2s 4.0 parati ang bida. Pero the readings is not the end of the story kaya famous ang d2s 4.0. Ang lux meter ay nilagay just below the step. Sa pag pili ng hid projectors di lang po kasi reading ng hotspot binabasehan. You have to consider beam width, hotspot width, may streaking ba or wala, type of cut-off, size and dimensions, ease of installations are some of the aspects when choosing a projector and also the price. Ako nga gusto ko sana oem projectors like 4tl or rx350 for its wide beam patern and hotspot pero di magkasya sa headlight ko. So I have to go with d2s 4.0.
Maraming ayaw sa step ng d2s 4.0 dahil masyado daw steep kaya minomodify ng iba ang shield nila. Naging famous ang d2s for its sharp cut-off and almost oem-like high beams.
here is a low beam of my d2s 4.0 and philips 85122 xv c1 bulb with morimoto xb35 ballast. About 4-5meters from the wall.
high beam
September 21st, 2017 08:16 AM #320
Nag try ako mag inquire ng Leoch brand sa FB page nila. The price is not cheap. Yung available for...
