Page 32 of 70 FirstFirst ... 2228293031323334353642 ... LastLast
Results 621 to 640 of 1387
    Apr 2006
    #621
    Quote Originally Posted by D3nb3r View Post
    ah ok. kala ko mh1 pa rin set up nyo now.
    hmm can't seem to upload pictures.
    Mar 2012
    #622
    Quote Originally Posted by wewoy_romero View Post
    nag iinarte na nga rin ang photo bucket, naniningil na hehehe. Try nyo imgbb na image hosting site.
    Mar 2012
    #623
    Quote Originally Posted by kkreuk18 View Post
    Ganito buga ng ksled sa halogen projector
    looks similar
    Jan 2008
    #624
    Tama nga pala ano. Buti na lang di ako sumugal sa led pnp
    Sent from my R7plusf using Tapatalk
    Nov 2011
    #625
    Mga sirs, paano ba alisin ung HID bulb sa projectors? Hindi ko ma-twist clockwise nor counter-clockwise eh.
    Pina retrofit ko to kay One Stop Customs last 2 years, stage 2 NHK projectors ata yung kinabit.
    Mar 2012
    #626
    Quote Originally Posted by TheUninvited View Post
    post pics of the bulb holder na walang naka kabit na igniter para malaman natin kung anong type yan.
    Nov 2011
    #627
    Di ko talaga matanggal. Hindi naman siguri irreplacable yung bulb diba?
    Eto yung pic
    Jan 2008
    #628
    Sempre napapalitan yan. Medyo nagtataka lang ako parang hindi d2s un bulb na nakalagay. Mini h1 ba yan mga paps?
    Mar 2012
    #629
    This is strange, your projector seems to be for d2s bulb since yung bulb cap ay similar sa mini d2s pero yung bulb na ginamit is pang mini H1 ata.
    I notice din na may tinaggal sa left at right part ng projector mo which is where the d2s bulb clip should be. I'm also assuming naka 90 degree offset ang phone mo nung kinuha mo yung pic na yan dahil yung na mention ko na parang ma tinanggal ay dapat nasa 12 and 6 o'clock position yan.
    I can see some dried glue/plastic welds near sa bulb cap. I just hope na di nilagyan yung threaded shaft nyan ng welds dahil if ganun it will be very difficult to change your bulbs let alone remove yung bulb cap pero no choice ka.
    Just turn the bulb cap counter-clockwise as hard as you can, walang ibang direction ang ganyan na bulb cap. Worst case scenario is palit ka projector.
    Jan 2008
    #630
    Definitely hindi d2s dahil walang socket. Tsk tsk... Sabi sa kin ni xenon, mas madali ikabit un bulbs sa hella g5 vs koito q5, both made by nhk
    Jan 2008
    #631
    Ganito dapat pag d2s
    Mar 2012
    #632
    Kaya sabi ko before na picturan nya ang bulb holder nya na walang igniter dahil I was assuming na d2s ang gamit. And yes d2s nga ang projector pero hindi ang bulb
    Jan 2008
    #633
    Tsk tsk.... Madaya a. Sorry bro pero hindi tama yan
    Mar 2012
    #634
    One more thing, MH1 bulbs ay known na parating may bulb seat alignment issue kaya pag konting kembot ng bulb seat ay di na tama ang output and tabingi na ang hotspots. Yan ang reason kaya may thread sa hidplanet about bulb shimming dahil sa MH1 though pwede din gamitin sa d2s ang method.
    Maselan na nga ang MH1 sa orginal bulb holder nya pano pa pag nilagay mo yan sa ibang holder na hindi sa kanya. Kaya kutob ko nilagyan welds ang bulb cap para hindi gumalaw dahil that bulb was never designed for that projector.
    Nov 2011
    #635
    Di ko pa rin ma alis. Napihit ko counter-clockwise ung parang gear na silver, walang nangyayari. Pati yung mismong black sa pinaka gitna (bulb na ata yun) ayaw pa din. naiikot ko sya actually 360 degrees pero ayaw mahatak. Ang masama pa, parang nasira ko lalo. Yung hotspot napunta sa leftmost side tapos tumabingi yung beam. di ko na mabalik!
    Asar na ko, pa retrofit na lang uli ako.
    Ok ba dyan kay Xenon Concepts? Mura eh. Stage 2 swak na?
    Balak ko din bumili new headlights, pwede na Depo for retrofit use lang naman noh?
    Di ko kase masyado kasundo yung sa One Stop pati yung gumagawa dun. May bad experience ako sa kanila ugh.
    Mar 2012
    #636
    Kutob ko nilagyan ng plastic weld or similar na pandikit ang bulb holder mo kaya di na ma galaw. Strange din na parang MH1 bulb ang nakalagay sa dapat d2s na projector.
    Yung pinihit mo na black na naka usli sa gitna, yan ay base ng bulb, so that means wala na sa alignment ang bulb seat mo at the moment resulting sa tabingi na hotspots dahil if properly installed yan ay di mo ma pipihit yan dahil yung tabs ng bulb base will prevent you from turning or rotating the bulb. Normally di mo mapipihit ang bulb pag naka scure na ang pwede mo lang ma pihit is ang bulb holder.
    Also tumabingi yung beam mo dahil nung pag pihit mo ng bulb holder ay kasama atang na pihit ang buong projector.
    Pwede pa naman ata magamit yang current headlight mo ngayun as long as walang cutting na ginawa sa reflector bowl mo. Yung projector na naka kabit sa HL mo ngayun ay bolt-on yan so dapat walang cutting na ginawa dahil ang threaded shaft nyan ay pasok sa butas ng reflector bowl at yun yung ang mag sesecure sa projector so no need na mag cutting at sang katerbang adhesive. Nag kacut lang ng reflector bowl pag oem spec ang projector na gagamitin.
    kreuk18 and si zechs ay kay xenon concept nagpa trabaho so far satisfied naman sila.
    Nov 2011
    #637
    Sige salamat. Concern ko is parang naka glue and patong lang yung projector/shroud sa reflector bowl and baka masira na yun in the process if aalisin then lalagyan ng new projector.
    Mura lang naman kase depo, unless hindi sya okay. Thoughts on Depo?
    Sige message ko na lang si Xenon Concepts.
    Jan 2008
    #638
    2 auto na pinaretrofit ko kay xenon concepts. Wala naman ako naging problem so far.
    Mar 2012
    #639
    Pakita mo muna sa installer kung may chance pa na magamit ang stock HL mo. IMO kahit may konting mga imperfection sa base ng projector matatakpan naman yan ng shroud. Wala pa ako experience sa depo headlights dahil ginagawa ko dati pag kailangn ko HL is kinakaibigan ko mechanic sa casa tapos sa kanila ako bibili ng headlight galing sa mga totally wrecked unit nila
    Nov 2011
    #640
    Nag pa-sked na ko kay Xenon Concepts. Yung stage 2.5 kukunin ko.
    Confident sya na kaya pa re-use yung headlights kahit naka glue/screw. We'll see. :D
    update ko kayo para sa mga interested.
Planning on getting an HID retrofit
