Page 34 of 70 FirstFirst ... 2430313233343536373844 ... LastLast
Results 661 to 680 of 1387
    Jan 2008
    #661
    Quote Originally Posted by KaiserRon View Post
    Question lang, malaki ba difference ng NHK bulb ni Xenon Concepts compared sa Philips or Osram?
    Sinabi naman sa kin ni xenon concepts na big factor ang bulbs. Pero ok naman ang nhk. Iba lang talaga un philips osram pagdating sa lifespan, kaya mahal
    Sent from my R7plusf using Tapatalk
    Mar 2012
    #662
    Check pics below for reference.
    Quote Originally Posted by s2kurt View Post
    Alright thanks bro. I doubt na mag ffit ang fxr sa gh ko. Ill keep the oem wiring ballast bulb set up and do only projector swap + maybe upgrade to the latest philips 85122 . My first choice is xenon concept since reasonable ang pricing nila.
    for oem spec projector na medyo maliit ang footprint, I'd go with the rx350 tapos lens swap sa sti-r lens. But then medyo madugo labanan sa presyo pag sa pinas na.
    Latest na malakas na bulb ng philips for me is the 85122xv c1, I have it right now pero di ko pa nakabit. Yung ultinon xv nila kasi is too white for my taste and useless sa akin yan since taga probinsya ako and parating may thick fog sa area ko not to mention heavy rains pag tag-ulan. Check the pics below for reference.
    #663
    Quote Originally Posted by D3nb3r View Post
    How much kuha mo sa 85122xv? Yung 85122 bulbs ko kasi parang di na kasing lakas compared to when I had my car headlights retrofitted (FXR/Philips 85122/Matsushita ballast) back in 2011. Must be because 55w ang ballast. Planning to have it replaced by the same shop na gumawa ng retrofit.
    Mar 2012
    #664
    Quote Originally Posted by marky2115 View Post
    Great setup up you got there. Iiksi talaga ang lifespan ng bulb pag ginamitan mo ng 55w. If you like may nilabas ang Profile Performance na bagong ballast ngayun that is 35w/55w. Bale mag 55w lang pag nag high beam ka at sa low beams mo 35w lang output nya.
    Yung philips xv ko nabili ko last time 175usd nung napunta ako US a few months ago, kaya bumuli na ako ng projectors, ballast and bulbs sa TRS mismo.
    Jan 2008
    #665
    Pair na un $175?
    Mar 2012
    #666
    Quote Originally Posted by kkreuk18 View Post
    Pair na un $175?
    yes, pair na po.
    Jan 2008
    #667
    yes, pair na po.
    Tsaka ko na iisipin yan pag napundi na lang un 85122 ko. Naka 35w lang kaya siguradong matagal pa bago masira
    Dec 2014
    #668
    Same lifespan with 85122? Hmm a bit expensive for a hundred more lux
    Oct 2003
    #669
    Planning to buy this bulb. Same ba ng sa iyo ito *d3nb3r?
    Also planning to buy DEPO replacement headlights para doon sa isang car. Kukunin ko lang ung lens nya para maging clear na ung cutiff nung isang retrofit ko. Will talk to xenon concepts uli kung mabigyan nya ako good deal if ever decide to get another set of hella g5.
    Mar 2012
    #670
    Quote Originally Posted by zechs View Post
    85122xv 2s1 po yung nasa pics nyo. yung sa akin s 85122xv c1
    Mar 2012
    #671
    Quote Originally Posted by hypnos View Post
    Same reason po why I buy a B&W hi-fi bookshelf speakers instead of cheaper HTIB systems like pioneer, kenwood or bose which ok if not excellent to some folks.
    Jan 2008
    #672
    Pero bilib ako dun sa hi arc bulb na pnp ko dati, di nagbago kulay nun in 2yrs, daily lumalabas un auto ko, mga *least 1hr na night driving
    Dec 2012
    #673
    pag bago pa both bulbs halos di mo makita ang difference nyan. Magkakatalo yan sa lifespan. You'll see na mag color shift na ng maaga ang nhk if compared to osram or philips and medyo mataas ang UV ng mga aftermarket bulbs kesa oem so careful ka when running it with 55w ballast sisirain ng uv ang chrome coating sa loob ng projector.
    Ahhh. Hintayin ko na lang mag color shift bago ako mag palit ng bulbs. Salamat boss
    Dec 2014
    #674
    Indeed sir. im sure it would blow others out of the water. what more if paired with s2k
    Nov 2011
    #675
    Ok naman so far ang Hella G5. Di lang aligned vertically (abot sa mata ng kasalubong na driver) and horizontally (not straight, sobrang naka focus sa left side, napansin ko yung step ng left projector is lagpas sa lane ko), inayos ko na lang. Also nag momoist sya sa both headlights, same part ng headlight.
    Aug 2012
    #676
    85122xv 2s1 = Xtreme Vision gen 2.
    85122xv c1 = Xtreme Vision gen 1.
    Sent from my ASUS_X00DDA using Tapatalk
    Mar 2012
    #677
    Quote Originally Posted by red_one View Post
    Nope.
    gen1 85122xv c1 +50%
    gen2 85122xv 2c1 +150%
    #678
    Hmmm. 4800K pala xv. Ok kaya to sa wet asphalt? Iniisip ko kung palitan ko na ballast ko to 35w then bulb replacement and maybe shroud na din since may konting deformation probably due to heat. Mapapagastos ata ako. hehe
    Aug 2012
    #679
    Nope.
    Nope.
    85122xv 2s1 is +150% also. See Philips data sheet.
    https://www.download.p4c.philips.com..._pss_enggb.pdf
    PHILIPS Xenon X-TremeVision Gen2 +150% D2S HID Xenon Bulb 85122XV2S1
    Amazon.com: PHILIPS Xenon X-TremeVision Gen2 +15% D2S HID Xenon Bulb 85122XV2S1: Automotive
    Mar 2012
    #680
    Nope.
    Edit: I was intrigued about this kaya I made some research. Actually same lang ata sila if compared(see pics below) now the reason why may dalawang bulb na same lahat ang specs sa isang site ng philips ay hindi ko alam.
    this is my gen1
    this the gen2
    comparison
    links:
    Philips Xenon X-treme Vision gen2 D2S HID Bulb (Single) | PowerBulbs
    Xenon X-tremeVision gen2 Xenon car headlight bulb 85122XV2C1 | Philips
    Products comparison
Planning on getting an HID retrofit
