Page 24 of 120 FirstFirst ... 142021222324252627283474 ... LastLast
Results 461 to 480 of 2385
  1. #461
    Quote Originally Posted by erick_214 View Post
    Tol...Yung hindi clear yung lens eh pwede mo ba gawan ng paraan para maging clear? May nabasa kasi ako sa isang thread na pwede raw lihahin yung lens eh...Na-try mo na ba gawin yun? Tsaka pwede ba ilagay yan dun sa panel ng fog lamps? yung sa hi-ace ko kasi walang fog lamps eh plano ko sana maglagay doon...
    yup I can do that, see my projects for the Trooper sa website ko http://www.hidretrofit.net you cant sand that down though improve muna your lighting sa main headlights before sa fogs. Anong oto ba bro? post a picture here para makita natin
    Dec 2010
    #462
    nakakabilib ang mga gawa ninyo sir!
    hays nung nakita ko yun sa photo gallery ng retrofit nio sa SiR eh parang gusto ko din, kaso sa province ako XD,
    di ko naman alam mga daan sa manila hahaha.
    bangis sir!!
    #463
    Can't wait to get my retrofit this April.
    Sir Gary question lang po. How does the HID fare on rainy conditions. From what I know ( which is very limited ), yellow lights are best for bad weather conditions. Can you please enlighten me? I'm thinking kasi if I will have my fogs retrofitted also or will I fit them with all weather bulbs for use in bad weather conditions.
    TIA sir!
  4. #464
    dalandan: tnx for your kind words bro. Pwede naman yan, you just need to send me your headlights. Am doing a JDM Fit right now, galing pang Mindanao and I just did a Safari 2010 from Bacolod so I can your SIR. Pwede mo LBC or AP Cargo.
    My latest. Trooper 2003 with modified H1, Philips china 4300k, the Apollo shroud has a angel eyes pero hindi naman nakailaw yun parang ring lang, ganda naman and of course custom clear lens.
    Eto ang tamang alignment for bolt on projectors. You see sa bolt on projectors it does not mean pag na-bolt on mo tama na yung alignment. Every single projector is unique and sa mounting you need to tweak it a little bit to get the correct alignment.
    and the output
  5. #465
    Quote Originally Posted by <smash> View Post
    TIA sir!
    4300k is best. Each bulb will give out around 3200 lumens and if you go 3000k or 6000k you lose at least 20% already sa output. There is a reason why all oem vehicles with hid syst use 4300k bulbs. Science lang yan and not subjective. Go muna with the headlight retro then see afterwards.
    #466
    Quote Originally Posted by garyq View Post
    Copy sir. thanks!
    #467
    Parang retrofitted lang ah ! Nice.
    #468
    yong trooper? alam ko retrofit po iyon MH1 projector, yon yata yong nakita kong ginagawa ni sir gary nong nasa shop niya ako
    #469
    Sir pa PM naman nung price magkano magpa retrofit sa inyo ng HID Projector Mazda2...
    #470
    Bro, parang iisa ang kulay ng mga Trooper na nagpapagawa sa'yo ah
    Excited na ako...
  11. #471
    SG: madami atang Trooper na Skyroof ganito ang kulay so naka tatlo na akong ganito ang kulay.
    Week 9 (Feb28-Mar.4) na ako free so pls confirm na your date para I can block off the days for you.
    #472
    Gary, ako din ha. SOON!
    Kaya 1 day sa trooper?
  13. #473
    s_qui: bro give me a sked na para I can block off the day for you. Better if we have more time to prepare. Anong month ba? Yes I can do it in one day.
    Dec 2010
    #474
    sir, if ever na mag pa retrofit ako ng oem setup sa civic sir, magkano po kaya aabutin? pa-pm na lang po.. and ok lang ba ang glare at output non kahit naka smoke headlights? thanks sir!!
    Apr 2009
    #475
    Sir if hindi kasama yung PHILIPS HID 4300k may bawas ba sa price also + smoke headlight na rin plan ko sana eh.
    #476
    Available pa March 1 or March 3?
    Final na bro.
    May 2010
    #477
    Sir, how much is the Bolt-on Projector just like what you installed on that Trooper above? is it at par or better with the Montero Sport and Fortuner OEM projectors?
    #478
    Final na bro.
    yun yun eh ! :clap: :clap:
    excited na ko makita to !
  19. #479
    SIRBoss: bro sobrang layo output nyan. The stock projectors of the Montero and Fortuner are halogen types.
    Montero stock:
    Output ng modified H1:
    will PM you. This is the best bolt on projector right now if you tweak it.
    SG; Yes pde March 1 confirm mo para I can block off the date
    Sanik: oo bro meron less pa. Pls PM me ano ba naoffer ko sayo? pagusapan natin
    dalandan: PM'd you
  20. #480
    My latest: Lancer/Cedia3 2010 modified H1
    comparing outputs taken from inside the vehicle
HID Projector Retrofits by garyq
