Page 20 of 120 FirstFirst ... 101617181920212223243070 ... LastLast
Results 381 to 400 of 2385
    Dec 2010
    #381
    Sir magkano pa retrofit headlight ng Honda jazz 2002?
    #382
    Quote Originally Posted by garyq View Post
    junkun: suggestion ko sa loob ng fog lights mo para Porsche style na DRL. I can retrofit 3 OEM leds sa loob nung fogs and wire it as a DRL. Ganda nyan
    chikselog: bro I suggest getting plug in LEDs for these. I have T10s and 7443 bulbs na LED.
    installed my aftermarket (bolt on) projectors sa dalawang Civic before ako mag break and eto results.
    LO
    HI
    To explain a bit about this setup. I have worked with many types of "bolt on" projectors and to tell you frankly, bolt ons are not really bolt ons if you want to do it correctly. Many of these projectors need some modifications to correct mounting and also to maximize output. One might say na ok naman as is, pero sa akin, nabuksan mo na rin lang, bakit di mo pa ayusin and mount it properly and get the max output from the projectors. I have also tried and tested many "bolt on" projectors and the one I am using now has the best output in terms of width and intensity. I modify these projectors to get the best output and mount it properly sa headlight. The harness and the sealant for this setup is also the same as my oem package so everything in the setup is designed for long term use.
    Sir, pa-PM naman po price ng ganitong bolt-on. Hehehe. Thanks!
  3. #383
    beni23: bro eto naman talaga ang budget setup ko for many months now and I think I sent you a PM before already. Anyways I will send you another PM. One year warranty and better than the output of Gen4-5. Ok some people asking me ano ba difference ng 'bolt on' projectors ko and my budget setup vs ibang bolt on setup. Here's the rundown:
    a. I use a different projector than whats normally offered ng ibang retrofitter. Different than Gen1,2,3 or 5. My modified bixenon projector gives out an intense and wide output. Wala pa akong nakikitang projector na 'bolt-on' that can match this projector as of today. Of course I can use cheaper projectors pero ang logic ko lang, you go through all the trouble in opening the headlights, mediocre performing projectors pa kakabit mo? doesnt make sense.
    b. HID syst: most bolt on projectors come with a packaged bulb and ballasts. I do not use these type of bulbs and ballasts coz in my experience they package the cheapest hid syst to go with the projectors and the bulbs/ballasts combo dont perform very well. I use Philips China bulbs and slim type ballasts with the same internals as oem ballasts and have a failure rate of less than 0.5%! Hassle mawalan ng ilaw sa gabi coz nagfail yung ballasts or bulbs.
    c. the shrouds I use are much nicer than the package shroud from bolt on packages. going back to the logic na ginawa mo na rin, gawin mo na ng mabuti at of course maganda,hehe.
    d. I use an oem spec wiring harness to power the hid syst. You dont want to fry your harness just to save 1-2k.
    e. Most 'installers' use silicon to reseal the headlight. I dont think you will see any oem headlights sealed with silicon. There is a reason for that. I use oem headlight sealant to reseal my retros.
    f. I offer one year warranty on all my retros, parts and service. I've done many retrofits in 2 years. Believe me, you would like warranty to be on your side and a reasonable time to get the replacement or repair the problem.
    g. I personally do all me retros with an assistant. This is something I am passionate about. I am not a hired hand and I value the work that I do.
    Doing a proper retrofit is not just opening your headlamps and sticking in a set of projectors. Well yun lang nga big deal na coz you will open your headlights and take apart the original sealant. Pag hindi properly nabalik, problema yan. well pag umuulan lang naman Many things you need to consider about the electricals, aiming, reliability, etc. Of course only if you want to do it the right way, you need to consider these things. I implemented the above improvements sa retro ko over a period of time and after doing many retros kasi I believe all the above things make for a better overall retrofit. I do not want to shave off a few thousand pesos tapos masama naman experience para sa client and sa akin. Several people inquired kasi and asked why the difference in price so I hope na explain ko ng konti.
    jazz4life: will pm you.
    Pls visit my website as I updated it before Christmas. >> http://www.hidretrofit.net
  4. #384
    TLZKWR projectors, Philips 85122+, Matsushita Gen3 ballasts, all OEM setup on Civic EK Sir
    Aug 2009
    #385
    Sir good day, how much po kaya para sa mitsubishi adventure gls sports 2010 model? Yung whole package po with installation and the item po for both OEM package and aftermarket. Pati pala sir anu po kaya marerecommend nyo sa akin? Salamat po.
    #386
    Wow. Naliwanagan na rin ako.
    Question pala, totoo ba na may life span ang FXR lens after 2000 clicks of high beam?
    Same with the Modified H1 projectors, meron din ba life span yung projector?
    Can we use the Apollo Shrouds / Lexus shrouds sa Modified H1?
    At... pa-PM pala ng total cost nung Modified H1, using my current ballast. Thank you in Advance. I hope makasunod ako kay denki this coming year
    Happy New Year Gary!
    #387
    Hmmmmmmmm ..... :um:
    #388
    Sabi nga ng erpats ko sa HL ni denki.. "Ayos.. Ang. Ganda ah. Linis ng pagkaka-gawa"
    #389
    Sabi na nga ba eh. Maganda kalalabasan pag dinala mo erpats mo eh ... :rofl:
    Pakitaan mo kaya ulit ng mga Genesis Coupe ? Baka magandahan din. :bwahaha:
  10. #390
    starexgold and tshan: will PM you
    re: solenoid
    I don't think so. Most electromagnetic solenoids are designed to have a life cycle of 1 or 2 million. At ten flicks/day, thats 100,000 days sa 1 million life cycle. It is a simple electromagnet so wala naman masisirang madali dun. Winding lang if ever and if you see the actual solenoid maganda naman quality and the moving part is very small. It would be the least of my concern. Just to make it clear, it is not the lifespan of the projector we are discussing but the solenoid or actuator that pulls down the shield when you flick the HI switch. Other than that the projector will last as long as the car if you use 35w bulbs.
    A blessed new year to all tsikoteers! Mabuhay tayong lahat!
    Jul 2010
    #391
    Hi. Can a Vitara JLX '94 be retrofitted as well? If yes, how much will it set me back? Pls PM me.
  12. #392
    kenn: pwede bro. I have been waiting for a project like this as I use to have a 97 Vit. Mas matagal lang bro coz I need to do the custom clear lens for the headlamps. Walang crystal/clear lens na aftermarket for the Vit so kailangan gawan pa. Will PM you
    Jul 2010
    #393
    ^^ got your PM pre. Need to think about this first. It's quite difficult to decide which one to give as a gift to myself. ;)
    Apr 2008
    #394
    Quote Originally Posted by kenn.garcia View Post
    Go for the OEM package na bro.. Hehehe..
    #395
    What are the choices ba ? Off-road setup ? Hehehe.
  16. #396
    Did this Pajero Fieldmaster before the new year kicked in. Naka Gen1 na bolt on. This was bought as a kit, 11k I think the owner mentioned tapos it was installed by a mekaniko. The output is so-so, one bulb (driver side) is kaput and the harness is malfunctioning already (can't drive the HI) sa driver side. All of these in over a years time.
    The 2 bulbs. One is dead already and the other one is in ICU
    The stock sealing was re-used and the sealant that came in with the kit. Kits use a grey sealant thats NOT compatible with the OEM sealant. They are totally two different materials.
    before and after:
  17. #397
    Results:
    Output
    Apr 2008
    #398
    Ganda ng sticker gary..
    Sep 2009
    #399
    Gary, oem setup for honda civic 2009 model 1.8s. may contact number ka ba? landline or cellphone
    May 2010
    #400
    Quote Originally Posted by Wilson CHong View Post
    click his siggy for his website..
HID Projector Retrofits by garyq
