Results 461 to 470 of 2382
- Dec 2002
- 2,335
February 6th, 2011 08:51 AM #461yup I can do that, see my projects for the Trooper sa website ko http://www.hidretrofit.net you cant sand that down though improve muna your lighting sa main headlights before sa fogs. Anong oto ba bro? post a picture here para makita natin
February 7th, 2011 12:04 AM #462
nakakabilib ang mga gawa ninyo sir!
hays nung nakita ko yun sa photo gallery ng retrofit nio sa SiR eh parang gusto ko din, kaso sa province ako XD,
di ko naman alam mga daan sa manila hahaha.
bangis sir!!
February 7th, 2011 11:44 AM #463
Can't wait to get my retrofit this April.
Sir Gary question lang po. How does the HID fare on rainy conditions. From what I know ( which is very limited ), yellow lights are best for bad weather conditions. Can you please enlighten me? I'm thinking kasi if I will have my fogs retrofitted also or will I fit them with all weather bulbs for use in bad weather conditions.
TIA sir!
- Dec 2002
- 2,335
February 7th, 2011 11:47 AM #464dalandan: tnx for your kind words bro. Pwede naman yan, you just need to send me your headlights. Am doing a JDM Fit right now, galing pang Mindanao and I just did a Safari 2010 from Bacolod so I can your SIR. Pwede mo LBC or AP Cargo.
My latest. Trooper 2003 with modified H1, Philips china 4300k, the Apollo shroud has a angel eyes pero hindi naman nakailaw yun parang ring lang, ganda naman and of course custom clear lens.
Eto ang tamang alignment for bolt on projectors. You see sa bolt on projectors it does not mean pag na-bolt on mo tama na yung alignment. Every single projector is unique and sa mounting you need to tweak it a little bit to get the correct alignment.
and the output
- Dec 2002
- 2,335
February 7th, 2011 03:29 PM #4654300k is best. Each bulb will give out around 3200 lumens and if you go 3000k or 6000k you lose at least 20% already sa output. There is a reason why all oem vehicles with hid syst use 4300k bulbs. Science lang yan and not subjective. Go muna with the headlight retro then see afterwards.
February 7th, 2011 06:12 PM #468
February 7th, 2011 10:29 PM #469
Sir pa PM naman nung price magkano magpa retrofit sa inyo ng HID Projector Mazda2...
February 8th, 2011 12:46 AM #470
Normal po Yan saken inde bababa need pa re start everybody can share same as my experience so I...
high idle RPM at engine start
