Page 196 of 239 FirstFirst ... 96146186192193194195196197198199200206 ... LastLast
Results 1,951 to 1,960 of 2382
    Apr 2008
    #1951
    stage 3 ito sir. ang pagkakatanda ko A3 Projectors (3" or 2.5"?) 35watts Philips bulb , It was fitted to use the same shroud ba yon kaya OEM ang itsura. lumaki nga lang yung mata heheheh.
  2. #1952
    jhn: by order yung D1S pero pwede naman. I also have the D1S CBIs if you like which I suggest you get and call it a day.
    xsalta: pwede naman pero meron tayong limitations.
    a. spare tail lights needed kasi matagal gawin
    b. clear lens dapat para kita na LEDs. One reason kasi is for better aesthetics
    c. the question of cost
    Maharot: 3" Koito projectors kinabit ko sayo not the standard A3's that we have. OEM na projector yan. 35w Philips ballasts and Philips 85122+ bulbs from Germany.
    Our first CX7: complete lighting upgarde for this car, vehicle specific mountings for the headlights and foglights.
    Mar 2012
    #1953
    Sir gary. curious lang ako. Ano po pinag kaiba nang A3 at Kioto oem projectors in terms of size, light width/ throw, foreground and cut-off? I've read that Kioto is used by S2000 and some Lexus and A3 is obviously from Audi. Thanks.
    Jul 2013
    #1954
    Quote Originally Posted by MR_MAHAROT View Post
    Sorry 50mm lang ung available na lens kaya hindi kita ung lapad nung ilaw. ipon ipon na for the projector fogs :D
    Ok na ok yang projector fogs sir ;)
  5. #1955
    Our LED tail light retrofit for the new Ford Ranger:
    side markers were also retrofitted as these are getting to be more standard especially among Ford vehicles.
    Sep 2013
    #1956
    sir how much po for Hyundai Tucson 2013? HID+projector and installation? TIA!
  7. #1957
    biggest challenge for us for this project was the space limitation and the placement of the DRL. Also the bezel for the fogs was redone as it was to plain to just have a flat shaped cover so we installed the same shroud as the HI side to add some texture and details sa fog bezel.
    Quad setup Crosswind, look was upgraded to '13 model by changing the HL, grill, bumpers and of course we did the quad setup for the headlights, DRL with dual intensity output (max at DRL function and 50% at park light function) and the fogs were transferred from the old fog housing to this with custom bezel and brackets.
    DRL
    and the tail light retrofit we did in the past
    Thanks Bri!
  8. #1958
    output pix:
    fogs only:
    HL only, LO
    fogs + LO
    fogs + LO + HI
    Apr 2008
    #1959
    ganda ng drl sa crosswind sir! pati na rin ung fogs after adding the shroud,mas nagmukhang oem.
    Nov 2011
    #1960
    Good day garyq
    question: u have idea on how the vios 3rd gen single bulb projector works? does it have moving parts to switch from low/high beam?
HID Projector Retrofits by garyq
