Results 1,951 to 1,960 of 2382
- Apr 2008
- 63
September 10th, 2013 11:46 AM #1951stage 3 ito sir. ang pagkakatanda ko A3 Projectors (3" or 2.5"?) 35watts Philips bulb , It was fitted to use the same shroud ba yon kaya OEM ang itsura. lumaki nga lang yung mata heheheh.
- Dec 2002
- 2,335
September 10th, 2013 01:17 PM #1952jhn: by order yung D1S pero pwede naman. I also have the D1S CBIs if you like which I suggest you get and call it a day.
xsalta: pwede naman pero meron tayong limitations.
a. spare tail lights needed kasi matagal gawin
b. clear lens dapat para kita na LEDs. One reason kasi is for better aesthetics
c. the question of cost
Maharot: 3" Koito projectors kinabit ko sayo not the standard A3's that we have. OEM na projector yan. 35w Philips ballasts and Philips 85122+ bulbs from Germany.
Our first CX7: complete lighting upgarde for this car, vehicle specific mountings for the headlights and foglights.
September 10th, 2013 02:00 PM #1953
Sir gary. curious lang ako. Ano po pinag kaiba nang A3 at Kioto oem projectors in terms of size, light width/ throw, foreground and cut-off? I've read that Kioto is used by S2000 and some Lexus and A3 is obviously from Audi. Thanks.
- Jul 2013
- 32
September 10th, 2013 08:02 PM #1954
- Dec 2002
- 2,335
September 10th, 2013 11:02 PM #1955Our LED tail light retrofit for the new Ford Ranger:
side markers were also retrofitted as these are getting to be more standard especially among Ford vehicles.
September 11th, 2013 02:31 PM #1956
sir how much po for Hyundai Tucson 2013? HID+projector and installation? TIA!
- Dec 2002
- 2,335
September 11th, 2013 08:09 PM #1957biggest challenge for us for this project was the space limitation and the placement of the DRL. Also the bezel for the fogs was redone as it was to plain to just have a flat shaped cover so we installed the same shroud as the HI side to add some texture and details sa fog bezel.
Quad setup Crosswind, look was upgraded to '13 model by changing the HL, grill, bumpers and of course we did the quad setup for the headlights, DRL with dual intensity output (max at DRL function and 50% at park light function) and the fogs were transferred from the old fog housing to this with custom bezel and brackets.
DRL
and the tail light retrofit we did in the past
Thanks Bri!
- Dec 2002
- 2,335
- Apr 2008
- 63
September 13th, 2013 12:13 AM #1959ganda ng drl sa crosswind sir! pati na rin ung fogs after adding the shroud,mas nagmukhang oem.
- Nov 2011
- 473
September 13th, 2013 12:14 AM #1960Good day garyq
question: u have idea on how the vios 3rd gen single bulb projector works? does it have moving parts to switch from low/high beam?
you apply lang sa mga outlines at crevices ng emblem na may nanigas na dumi... ok na yan, make...
"Tamang OC lang" - a newbie's guide to car...
