Page 96 of 120 FirstFirst ... 46869293949596979899100106 ... LastLast
Results 1,901 to 1,920 of 2385
    Mar 2012
    #1901
    Quote Originally Posted by rwesley View Post
    Actually clear lens lang sya hinde ko na pinakulayan baka makaapekto lang sa visibility ng HL, white color ang AE at naka tap sya sa park light switch para may switch pa rin sya if i wish na off ang AE, i will post the night output soon.....
    what i mean po sa painted shields is yung shield nang projector behind the bulbs and not the lens po. i dont think it will affect the visibility dahil yung makikita natin na color sa lens is reflection lang of the painted shield dun sa projector. but anyway, that is just me so bale yung park light nyo po is same switch as the angel eyes?
  2. #1902
    No the shields are not painted and I wala naman reason to paint it. also the angel eyes are tap to the park light.
    guys: sent you PM
    #1903
    Quote Originally Posted by garyq View Post
    guys: sent you PM
    sir gary thanks sa retrofit.... hinde ko pa naadjust, mababa pa ang mounting ng low beam, just a little bit adjustment lang naman.
  4. #1904
    ok just use the stock screws for up/down adjustment. 25ft away from the wall, mga 36" height nyan or less
    Accent Stage3
    Optional LED DRL
    Tried to go as close to the OEM type na headlights with projectors and OEM naman dumating.
    #1905
    ^ sir gary, eto na yung light bar para sa accent? kaya ba yung ganitong style?:
    https://www.facebook.com/photo.php?f...type=1&theater
  6. #1906
    170: pwede. see also exledshop.com as we re-sell for them and also install
  7. #1907
    peugeot 3008 fog lamp retrofit.
    OEM look and function.
    you can see here the output of the stock halogen HEADMLAMPS (left picture) vs. the FOG retrofit (right picture).
    The output of the fogs is more intense and wider than the stock halogen HL. This setup will at least double your lighting output.
    Nov 2012
    #1908
    Hi Gary, here are some pics of the issue I had earlier today.
  9. #1909
    Sked mo lang na madaan sa shop. a 50% moist coverage on the HL is acceptable as per oem specs provided nawawala pag uminit coz sometimes pag very humid at nababad, the cold air inside cant vent out. Problem yung pag nag tubig and pag ganun meron leak talaga. SMS me sa 0908 8183545. Pwede bukas.
    Nov 2012
    #1910
    Ok, sent u a messg already
    Apr 2008
    #1911
    Hi sir gary.para sa fogs gano po katagal ang pagkakabit and ilqng mm po for alterra 2013? Thanks po
    Sent from my GT-N7100 using Tapatalk 4 Beta
  12. #1912
    mrmaharot: kasya 70mm dun. If you come ng 8-9 am mga 4pm tapos nyan. SMS mo ako 0908 8183545
  13. #1913
    twins
    Honda City 2012-13, stage2 with LED DRLs and angel eyes for park lights
    Nov 2012
    #1914
    Sir garyq nag pm po ako about toyota vios retrofit and quotation for projector headlight /angel eyes 2nd gen toyota vios 1.3g
    thanks in advance!
  15. #1915
    duran: wala ako natanggap bro, pls re-send it or maybe also send it sa garyq7*yahoo.com
    Nov 2012
    #1916
    Done, email and tsikot inbox.
    thanks ulit!
    Jul 2013
    #1917
    twins
    Sir Gary,
    Pa PM po ng price sa ganitong set up. Planning to upgrade my city nagrereklamo si mrs pag nagmamaneho sya sa gabi.
    Thanks in advance sir.
  18. #1918
    New Daylight Running Lights for Mitsubishi Adventure, LED with diffused output:
    Also stage3 retrofit plus 70mm fog retrofit
  19. #1919
    Ranger Wildtrack 2013 4x4 Stage3 package
    Apr 2008
    #1920
    i cant wait to have mine done this saturday :D
HID Projector Retrofits by garyq
