Page 199 of 239 FirstFirst ... 99149189195196197198199200201202203209 ... LastLast
Results 1,981 to 1,990 of 2382
    Jun 2013
    #1981
    Hi sir,
    I was the one who texted before. I would like to ask if this can be done. Something like the post of arki_j on the other thread.
    http://tsikot.com/forums/hyundai-car...ml#post2027997
    For my white Accent Hatchback.
  2. #1982
    coolgrease: yes pwede natin gawin yan pero we will use oem projectors. bolt on yan mga ganyan na setup, output and reliability malayo sa oem setup.
    OEM SMDs for my tail light retrofits
    #1983
    Quote Originally Posted by garyq View Post
    I dont have LED foglamps because they will not contribute to better lighting output. What I offer is HID projector for fog application.
    So how much would be d total cost for the HID fogs? Pls pm me.. Where can I find your shop? Thanks!
    Sent from my iPhone using Tapatalk - now Free
  4. #1984
    Our first 2013 Ford Fiesta
  5. #1985
    SIR never goes out of style, hehe.
    unique aftermarket HL with HID projectors retrofitted and also first time for the 70mm fog setup to get mounted on the EK body.
    Sep 2012
    #1986
    sir gary ask ko lang po kung magkano para sa montero sport 2013. kc naka projector headlight n papalitan lang b ng bulb un or babaguhin lahat? ska how much pag head light lang? ska kung s foglight magkano din po. thanks.
  7. #1987
    Our first Honda City 2013 GM Full LED retrofit.
    Retrofitted on "like new" set of OEM tail lamps
    using: OEM leds for park (driving) and brake functions
    with led side markers:
    park or driving lights ON
    brakes ON
    Decided to re-design the lighting function vs. the original. In my opinion mas "pansin" during braking na meron set of lights turning ON vs. light na nag increase lang sa intensity. Also yung clear lens na part nung TL maganda lagi naka ON sa park lights kasi pansin na LEDs and the long led bar naman, we installed high intensity LEDs for brake function. I love the way this turned out. Bagay na bagay sa GM, I think.
    Feb 2012
    #1988
    Thanks uli sir gary for the work on my accent HB, 50mm foglight hid projector retrofit plus wiring work for the 2014 spec OEM projector headlights w/ DRL :D
    Galing ng wiring work nila, oem spec ang dating...best wiring work ive seen so far compared to other shop's wiring work when installing aftermarket accessories
    Apr 2013
    #1989
    Sir gary, have you done e36 bmws? Could you post pic? Tnx
    Sent from my G-Note 2
    Sep 2009
    #1990
    a few months in the making and finally....
    perfect fit for the CX9. oem in form and function
    Hi Gary, quite busy these days but I still need to bring it again at some point. The bulb change did not address it. Thanks.
HID Projector Retrofits by garyq
