Results 2,051 to 2,060 of 2382
- Dec 2002
- 2,335
- Aug 2005
- 18
January 23rd, 2014 05:58 PM #2052Hi Gary, saw your projects and i'm interested. Can you pm me the price and the specs of the stage 1, 2 and 3 retrofit for the 2014 Montero? Tia
Sent from my iPhone using Tsikot Forums
- Dec 2002
- 2,335
January 24th, 2014 05:01 PM #2053gabo: sent you a PM
Vehicle specific DRL/fog light assembly for Hyundai Accent 2012-13. Dual intensity output for DRL function and parklight/driving light function. Complete with auto module and wiring harness
January 24th, 2014 05:54 PM #2054
January 24th, 2014 07:39 PM #2055
To rephrase my question: How many inches should the fog light cutoff be from the head light cutoff and at which specific distance from the wall? Thanks.
EDIT: I know that head light/fog light aiming is a complicated issue (lamp axis height, etc.) and I'm probably oversimplifying it. But I was hoping you could give me a rough and general idea. Failing that, I just might go back to you for a fog light retrofit. Haha.
Sent from my Galaxy NoteLast edited by Pipefish; January 24th, 2014 at 08:26 PM.
January 24th, 2014 08:54 PM #2056
OK, here's a more intelligent question: How many inches below the fog light axis/center should the cutoff be at 25 feet? 2 inches? 2.5 inches? 3 inches? What do you normally use? Thanks.
- Dec 2002
- 2,335
January 25th, 2014 03:29 PM #2057same way you adjust the HL. 25ft away on flat surface, measure from ground to middle ng fogs, project to the wall and this is your cutoff height. But with your stock fogs you can only approximate this.
January 25th, 2014 04:12 PM #2058
Thanks, Gary. So no need to measure 1.5"-4" below the center of the fog light? Anyway, napapagod na 'ko mag-DIY. I managed to convert the projector from my stock head lights, after your retrofit, by sealing the holes. I have a nice cutoff (and the projector is big, maybe about 2.5") but the projector is not stable. I have a feeling pag nalubak ako uurong siya. Haha.
January 25th, 2014 04:37 PM #2059
Gary, 'yung fog light retrofit mo ba kasing-sharp ang cutoff ng sa head lights? At gaano katagal gawin? May stages din ba 'to (1-3) o isa lang? Kasing-liwanag ba ng H1 mo 'yung D2S Stage 3 ng head lights ko at same color? Thanks.
- Dec 2002
- 2,335
January 25th, 2014 05:08 PM #2060yung 70mm yes, very sharp but more important, kasing intense and wide yung output. isang package lang. 4300k din
you apply lang sa mga outlines at crevices ng emblem na may nanigas na dumi... ok na yan, make...
"Tamang OC lang" - a newbie's guide to car...
