Page 170 of 239 FirstFirst ... 70120160166167168169170171172173174180220 ... LastLast
Results 1,691 to 1,700 of 2382
  1. #1691
    Quote Originally Posted by junkun13 View Post
    sige sir sched natin this week, ikaw na magsabi ng date
    wed pwede this week
  2. #1692
    Complete lighting upgrade for H4 type halogen headlights.
    Stock output, LO
    Halogen upgrade using Philips XV
    LO output
    HI output
    This is a good upgrade if you have a limited budget. The output will increase by 10-20%, conservatively IMO, 10-15%. Some common questions:
    FAQs for this upgrade:
    Kailangan palitan yung socket ng H4?
    No, coz these are stock wattage meaning pareho ng consumo sa stock bulbs.
    Pwede na ba eto pag naka dark tint?
    Hindi, I am 100% sure, get a lighter tint coz tint pinaka kaaway ng lighting output. Cheaper solution if you get a lightet tint.
    Pwede na ba pag naka med tint?
    some people ok naman, some people kulang pa rin.
    Who are the best candidates for this upgrade?
    cars with old halogen bulbs and limited budget for the meantime.
    Ano mas ok Osram NB or Philps XV?
    In my opinion and I work on headlights and lighting outputs everyday, either will give you better output than stock bulbs but side by side, hindi ganun ka significant difference.
    Where can I buy? PM na lng, I keep these in stock
    Hi wattage halogen bulb, 100/90w
    I cannot suggest coz many cars are adversely afftected by the high heat generated by these bulbs. Some wala naman so it's up to you but I cannot suggest it.
    Our PLUG and PLAY HID bulb with LO and HI output mechanism
    LO output
    HI output
    FAQ's for this upgrade:
    Salpak lang ba eto sa H4 headlight?
    yes, walang modification
    Ano included sa setup?
    D2S aftermarket bulbs (oem pwede rin), wiring harness, 35w ballasts
    Meron bang glare sa kasalubong na traffic?
    very minimal, hindi nakakasilaw
    Meron bang cutoff?
    meron although not as defined as HID projectors pero meron.
    Meron ba para sa ibang headlights like HB4, etc?
    Wala, sorry, H4 lang for now.
    Ano difference neto sa mga pnp sa Banawe or other auto accessory shops?
    The design of the mechanism mimics that of an oem reflector type HID headlights. FIxed yung D2 na bulb and a shield moves to give higher cutoff. Yung sa mga China na plug and play, either magnetic na gumagalaw yung bulb (many know sirain eto) or there is a tiny halogen bulb that turns ON during High which is really nothing The mechanism of our PNP H4 is tested/mfg for 1M actuations. I also use the best aftermarket D2 bulb and oem spec 35w ballasts, NOT boxed items or kits. Kaya mura yang mga naka box na HID kasi the traders get the cheapest bulbs, ballasts and stick it in sa box and sell it. Meron nga warranty, magsasawa ka naman sa kakabalik tapos hassle mawalan ng ilaw sa gabi.
    Where is this made?
    Taiwan
    Why did you start offering this upgrade?
    Some people wala pang budget for a retrofit kahit stage1 but they want better lighting without glaring others. The cost of this upgrade is midway ng stage1 retrofit and plugandplay HID setup. I am encouraging people who are on traditional pnp setup na meron glare to move to lighting systems na hindi nakakasilaw, kahit this system or even halogen lang.
    And of course, our retrofits from stage1 to stage3
    I have a complete write up on this sa HIDRetrofit.net
    #1693
    Thanks sir Gary for doing my project:
    DRL
    LED rear reflector
    #1694
    Magkano PNP hid kit mo, bro. Gary? Pa-PM naman. Thank you.
    #1695
    Sir gary ygpm po. Thanks
    Nov 2012
    #1696
    Sir Gary humhaba listahan ng papagawa ko sa TB ko hehehe
    DRL
    LED rear reflector
    #1697
    DRL
    LED rear reflector
    wow another masterpiece by Sir GaryQ! i love the DRL
  8. #1698
    Sorry hindi na clarify yung install sa SF DM. I am an official installer of EXLED Korea and the Leds are from them, I just installed it. I can offer the complete upgrade, parts and installion.
    bumper mounted LED lighting retrofitted behind the reflectors, double intensity:
    Park lights
    Brake lights
    Daylight Running Lights retrofitted inside the fog lamps, functions as DRL and meron din turn signal which the client did not want to be connected:
    This is a 4x4 unit so oem yung HID sa headlights. The optics on the projectors are square!! not just the shroud. Quite different. I can retrofit the 4x2 with HID projectors. Ok naman yung OEM HID, D1S, cutoff not sharp but width and intensity is ok. Well for a 2.2M vehicle it should be
    Nov 2012
    #1699
    May EXLED ba for trailblazer? How much na kapag stage 3 HID retrofit and lahat Ito sa likod
    Quote Originally Posted by garyq View Post
    Park lights
    Brake lights
  10. #1700
    wala pa for now but I can custom build one for you. I need to see the unit though. When ka ba pa sked for the retrofit?
HID Projector Retrofits by garyq
