Results 1,011 to 1,020 of 1594
December 30th, 2014 12:51 AM #1012
Not on paper. All AT's I've driven except our old 2.0 Altis had transmissions that shifted down as soon as you prodded the throttle hard enough.
Still not as engaging as an MT, but when you're crawling in EDSA traffic, do you need engaging?
December 30th, 2014 02:19 AM #1013
Sir andrewnathaniel,
Matipid talaga ang MT, kasi maliban sa mechanical type ang transmission, nasa "Driver" ang control ng sasakyan, kung paano patatakbuhin yung sasakyan, kung normal, severe, at extreme driving.
Sa AT naman, Hydraulic type transmission (yung iba is CVT/Dual Clutch Transmission) , so computer based naman at inter-related sa Engine ECU, kahit anong application ng driving, still the computers will control the fuel flow, and the appropriate gear na suitable in driving condition, kaya merong delay.
Bakit ba umaabot sa 3K RPM pag MT?!
Commonly nangyayari sa mga Driver transition na galing gasoline fed engine to diesel engine vehicle.
If a certain driver na diesel experienced at conventional diesel ang dala (non CRDi),
kung merong idea sa automotive technically when , from full stop, kung acceleration, standard ang 1st gear * 3K RPM.
Literal na driver, start naman * 2nd gear, ang main reason naman nila is kaya naman ng makina at ayaw nila mabitin when it comes to acceleration.
kaya kung sa saving for a long period? fuel or transmission?
When it comes to CRDi lalo na kung VGT/VNT or other na tawag ng turbo ng certain car manufacturer.
kaya ba tumakbo ng 2nd gear start?! Yes! kaya ng engine, pero yung wear and tear ng clutch? madaling masira.
kung sa AT, kahit naka V, ramdam pa rin yung turbo lag? at delay during acceleration?, it's a "safety feature" para merong enough response time if in case na accidentally instead of brake pedal ang matapakan at accelerator pedal in a confined area lalo kung maraming tao/property na pwedeng mahagip. 3 seconds delay is reasonable at safe enough for presence of mind pag dating sa awareness, shift from D to N, step on the brake pedal and pull the handbrake.
Kung sa MT, lalo kung naka VGT, seriously, unting pagkakamali ng timing sa pag bitaw ng clutch? damage will be very inevitable lalo pag confined area, sa traffic, community area, at even sa grahe.
December 30th, 2014 02:27 AM #1014
Kelan pa naging safety feature ang lag ng response ng kotse.
Buti nalang hindi ganyan mag-isip mga car manufacturer. Baka yung sunod na Volvo 10 seconds na bago magkaron ng response.
December 30th, 2014 02:37 AM #1015
December 31st, 2014 01:28 AM #1016
I don't know about most drivers out there, but it's my RIGHT foot that actually does most of the work alternating between gas and brake pedals, whether driving an M/T or A/T; that's why traffic has never been an excuse for me to go slushbox. The left foot has that one job of just actuating the clutch.
December 31st, 2014 02:24 AM #1017
In stop and go traffic, you're usually stuck in first gear and you'd have to modulate the clutch to keep from stalling, and also to get the car to move a few inches. This is what's tiring for people especially if your route is Makati-QC or BGC-Antipolo.
You can't just use the brake and gas in this situation - without stepping on the clutch your car will be jerky when you accelerate and will stall when you brake to a halt or to a very low speed. I haven't driven an MT that doesn't need clutch modulation at crawling speed.
December 31st, 2014 10:24 AM #1018
Yes, and it just boils down to the individual driver. I travel from Antipolo to QC and back on a daily basis; half an hour of heavy traffic out of 1.5 hours of travel is no big deal. I remember months ago having to endure heavy weekend traffic from MOA to Antipolo, and it was my right foot that was so sore having to work the pedals.
- 54,205
December 31st, 2014 12:38 PM #1019if your pedals (especially the clutch!) and steering wheel are light, your seating ergonomics agree with your body, and your aircon works fine, you won't think too much of shifting to AT.
first thing i look for when i am considering an MT car, is the clutch pedal.
- Jul 2008
- 935
January 1st, 2015 03:20 AM #1020If I drive around the metro, Ill choose AT, I guess this will just boil down on how comfortable a driver wanna be in a 3 hour traffic....
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
