Page 98 of 160 FirstFirst ... 4888949596979899100101102108148 ... LastLast
Results 971 to 980 of 1594
    Apr 2010
    #971
    for a brandnew vehicle, when is the earliest possible change in ATF? thanks
    earliest possible change in atf? every oil change? check with your manual. Usually every 40k. Kung run-of-the-mill transmissions lang that accepts Dexron III fluid, Php250 or less lang per liter neto and you would need mga 4L or so. Pwede na isabay every 3rd or 4th change oil kasi mura lang
    Sucks having m/t here in metro manila, sa probinsya ok lang.
    #972
    thanks particle x
    Posted via Tsikot Mobile App
    Jun 2011
    #973
    Mahihilig sa driving mas prefer M/T, mas nararamdaman hatak. Katuwiran ng iba nakakapagod daw M/T pero di lang
    naman driver ang pagod sa pagbibiyahe pati pasahero na di naman umaapak ng clutch at nagkakambyo
    pagod din.
    Jun 2014
    #974
    When u are over 40 years old i suggest u get the AT trans because the daily pressure of the clutch will eventually wear your lumbar (spinal connecting your pelvic bone) resulting in low back pain in the long run. By the time u notice it, some nerves may have been compressed by the pressure and it may result in numbness in some parts of your legs
    Jul 2011
    #975
    resulta yan sir ng improper sitting position, pero pag ganyan edad madali ng mapagod paa at lumalabas na rayuma :D
    Jul 2011
    #976
    pero malaking ginhawa ng a/t ngayon, thumbs up ako sa reliable a/t ngayon, pag daily driven.
    pag rezing rezing, off road m/t.
    Jul 2011
    #977
    *bf2000anu yun sir? glitch sa tsikot o spambot ka?
    Apr 2008
    #978
    I remember our lolo driving a manual transmission car on a daily basis even when he was already in his 60s. No complaints whatsoever. Now already in his late 70s, he still drives a manual on occasion when his matic car is being serviced.
    Sent from my GT-I9100 using Tapatalk 2
    Jul 2011
    #979
    baka nakaranas pa yung lolo mo double pump sa clutch before shifting.
    pero sa traffic talo talaga manual sa auto sa ginhawa ng pag drive.
    pero either m/t or a/t ok lang, kung ayaw nyo sa trans nyo bigay na lang saken kasama na car :D
    Aug 2008
    #980
    I am 32 years old now back when i was still in the Pi ayaw ko bumili ng A/t kasi nasanay ako talaga sa manual bago ako nag migrate dito bumili pa kami strada na m/t,never ako nag drive ng a/t noong nandyan po ako ayaw ko kasi a/t parang pang matanda sabi ko sa sarili ko pero nagbago lahat po yon nung naka pag drive na ako ng a/t dito sa US parang ayaw ko na mag drive ng manual dahil sa comfort at walang kapagud pagud na pag drive.dati mag drive ako ilocos to manila pagud na ako sakit katawan pero dito sa US kapag mag long drive kami ng family ko hindi ganun kapagud kahit x2 sa distance ng travel ko jan noon. So pag uwi ko trade ko na m/t strada to a/t
Battle of the Transmissions: M/T vs. A/T
