Results 571 to 580 of 1594
November 9th, 2010 01:37 PM #571
November 9th, 2010 03:14 PM #572
That mostly applies to older A/Ts. Newer ones are more intelligent and will automatically down-shift or up-shift depending on road grade, speed, engine load, RPM, throttle position and brake pedal position.
For rare situations wherein you need to lock or limit the A/T's intervention, a set of fixed gear positions (ie. L1, 1, 2 or L2), limited gearing (ie. D3) and/or sequential manual gearing are usually available to give the driver a bit more flexibility. But in most typical driving situations, you'll be fine with D.
November 9th, 2010 03:50 PM #573
My A/T car is 09 Fortuner 2.7 vvti I don't think this is old, my previous a/t cars were Xtrail 200X, City idsi 7 speed CVT, neither these.
IMO, M/T is better during uphill you can proactively select to the correct gear right on time before the speed drops due to inclination, not like in A/T it's a reactive shifting, it will shift if it senses difficulty, there is already a drop in speed before it down shifts so bitin. That's why I use 2 during uphill like kennon, its shifting is quicker than D
November 21st, 2010 06:03 PM #574
If I'm going to drive through flooded streets water level around half the wheel base, I would definitely not be wanting to drive my a/t car, any floods m/t is the only thing for me.
November 22nd, 2010 01:47 PM #575
yup, palit lang ng gear oil kung malalim talaga ang baha pero at least kaya pang paandarin at of course, any gear oil will do.
sa matic, masyadong sensitive pagdating sa ATF, maaari pang malitson kapag nalusong hehe.
anyway, bihira lang naman yung ganitong pagkakataon siguro.
November 22nd, 2010 03:11 PM #576
But technically, you stand a better chance of driving out of a flood in an A/T than on an M/T. A/T assemblies are practically sealed. The only time water could get in is through the breather tube or dip-stick. However, these are usually situated high up and above the A/T assembly. All friction parts in an A/T are effectively sealed from the outside.
On the other hand, once water breaches the clutch housing of the M/T assembly (which is one of the lowest parts of the car), you're likely to be immobilized.
- Dec 2008
- 421
November 22nd, 2010 03:23 PM #577
November 23rd, 2010 02:49 PM #579
Just yesterday when it rained heavily, the flood outside our street is about 4 and a half inch deep, my City type Z m/t was able to wade through the flooded street, our Civic Vti 2000 although may be able to pass our streets but I would not gamble on my car's a/t.
I was able to negotiate the flooded street in 5 to 10 minutes at 1st gear around 10kms per hour, versus my vti the gear would have to shift to 2nd when I hit at least 20 kms/hr, otherwise the car would stay in 1st gear around 1.5k at the tacometer, that would not be an ideal position to be in the flood.
November 24th, 2010 11:22 PM #580
During Ondoy, I spent several hours driving through floods for relief missions in my manual transmission Crosswind... in water so deep that my electrical system conked out at times.
Manual trannies are not vulnerable to floods. Most modern automatics, on the other hand, are electronically controlled... and unless they're specifically sealed, those control modules can short... and from experience... they cost a heck of a lot.
Better to buy the similar-era clone starex 4x4 (not sure lang if local or imported but original lhd...
Mitsubishi Philippines
