Page 381 of 392 FirstFirst ... 281331371377378379380381382383384385391 ... LastLast
Results 7,601 to 7,620 of 7833
    #7601
    Any recommended Dual Action polisher na entry level, mura, at noob friendly?
    Matagal nako nag dedetail pero hesitant talaga ako sa DA, dibali nang pagod basta diko makaskas/masunog base coat ko hehe.
    Marami na option sa Lazada or Shopee, pero diko pa alam ano yung universal pag dating sa pads, para atleast sa pads ako mag invest.
    #7602
    Quote Originally Posted by marvin14 View Post
    Thank you Sir!
    andami pa palang aaralin pag mag popolish
    mukang mas okay kung hindi ko na tanggaling ung clay marring hehe
    I'ts better for you to get to the basics, as you have many questions that are mixed up.
    Start from here:
    Clearcoats are thin by Mike Phillips
    Thank you Si0r!
    May nabasa ako na meguiar's cleaner wax
    Meguiar's(R) Cleaner Wax, A1216, 16 oz., Liquid | Meguiar's
    sino nakapag try na nito po? effective ba?
    Tried this already. It wont help with your issue.
    #7604
    Quote Originally Posted by ronki View Post
    Bro head over to Reflections care, Ginnova sa tsikot.
    Madami siyang DA that suits your budget, Griots, Porter Cable, etc
    Apr 2012
    #7605
    Thank you Sir!
    best tip: read the 1st 10-12 posts of this thread by sir scharnhorst and you will learn a lot about car detailing.
    huwag ka matakot sa DA at hindi basta2x makaskas/masunog ang paint dahil nag-oscillate o umiikot in elliptical pattern. kung matagal ka na nagpolish by hand then its the right time for you to level up and use a polisher. check out reflections car care as mentioned earlier, maraming polisher si sir ginnova. shinemate yata yung pinaka-affordable.
    #7606
    Yup sulit yung sub 10k na shinemate, complete with 6 pads.
    I guess swak na to partner sa Hybrid Solutions Polish and Wax as AIO.
    Aug 2020
    #7607
    ang mahal namn nyan boss, meron ba sa laza DA na within 2-3k budget hahaha
    Aug 2019
    #7608
    Start from here:
    Thank you Sir!
    Okay po.
    Thank you Sir. finished reading up to page 25 of the thread, naka center po ung discussion mainly sa washing and waxing.
    I also took my time to browse tsikot forum pero parang wala pong thread ng tutorial ng polishing. or baka hindi ko lang nakita?
    decided na akong mag polish para mataggal ung clay marks
    baka ang gamitin ko nalang is meguiars ultimate polish as advised. maghahanap palang ako ng pwedeng polishing pad.
    puro pang machine ung nsa reflections car care website so baka sa ace nalang muna ako mag hanap
    #7609
    Thank you Sir!
    Okay po.
    This might help you with your car polishing endeavor.
    Dual Action Orbital Polisher Guide: how to remove swirls, scratches, & oxidation with an orbital buffer. Porter Cable 7424, foam pads, backing plate,
    How To Remove Swirls, Scratches and Water Spots with Mike Phillips on Motorhead Garage - YouTube
    #7610
    #7611
    i do not see any.
    #7612
    Meron nga, parang mantsa.
    Bago ba yung car o paano nangyari?
    #7613
    Less than a yr old. Parang mantsa nga, dont know what happened, bigla nalang nagkaroon
    #7614
    try mo muna cleaner wax bro, or polish lang
    #7615
    Nangyari din kasi sa akin after 4 months at sa hood din at ang nakapansin ay si Rovic of PDR.
    Nagcompare ako sa ibang unit at confirm ko na iba nga yung sa akin at ibinalik ko sa casa at ipina-repaint ko yung hood under warranty.
    In the mean time subukan mo yung advice ni ninja and I would use Meguiars.
    Jan 2008
    #7616
    parang may mantsa.. try using polish or rubbing compound (yung light lang like mothers or any light polish)
    minsan sa wax yan eh.. parang nag trap ng dumi
    #7617
    Quote Originally Posted by razerph View Post
    Yup, waiting lang baka may mag feedback dito hehe.
    Aug 2019
    #7618
    mga sir, anong tingin nyo dito sa combo na to? okay kaya to o hindi sulit?
    turtle was seal and shine
    Collinite 845
    As of now ung 845 lang gamit ko. nilalagay ko lang cya after carwashes
    mas okay ba kung gamitan ko muna ng TW seal and shine bago ako mag apply ng 845?
    Thank you
    #7619
    I'll be using this AIO on a new car from the casa.
    There will be a lot of imperfections to expect so I'm thinking of getting a DA polisher, but I have a few questions.
    The backing plate (velcro) is 7", should the pads be 7" as well or 8"? Microtex only has 3, 6, and 8 inch pads.
    What's the benefit of having a waffle pad?
    Based on the AIO that I'll be using, should I use a cutting/polishing pad or just a finishing pad?
    Thanks.
    I'm heading to youtube after this.
    Jan 2008
"Tamang OC lang" - a newbie's guide to car appearance maintenance
