Page 379 of 392 FirstFirst ... 279329369375376377378379380381382383389 ... LastLast
Results 7,561 to 7,580 of 7833
    Wala ba malapit na grocery sa inyo?
    How about baby shampoo or body wash? pwede kaya yun n alternative?
    Yeah ph balanced shampoos hmmm not sure if it will have cleaning power lol...
    Sep 2010
    #7562
    Guys ano maganda alternative sa car shampoo?
    Naubusan ako and lockdown pa din walang mabilihan.
    Any suggestion? ok lang ba pang laba?
    Sa pagkaka tanda ko sir, may nag post dito na pwede ang hair shampoo gamitin as alternative sa car shampoo.
    Eto ung link sir: Hair shampoo as car shampoo
    Apr 2012
    #7563
    imo, pwede na ang hair shampoo kung walang wala na[emoji51] lubricity na lang habol. rinse thoroughly lang at dont allow to dry to avoid streaking. apply wax or sealant after
    Jan 2008
    #7564
    Wala ba sa gas station? If i were you, just use running water in mist and super wet towel
    walang lubricity ang water. those very hard to see "abrasives" (dust/small sand) will mar or even scratch the clearcoat or last layer.
    Apr 2012
    #7566
    agree, lubricity is the key[emoji106]
    Jan 2008
    #7567
    Of course you need to remove the sand and dirt using pressure washer.. running water will be your lubricant and dirt will go down with the water. Just make sure to clean the wet towel every wipe.
    Jun 2005
    #7568
    Hair conditioner
    Sent from my MI MAX 2 using Tapatalk
    Dec 2017
    #7569
    This is my "quickie" way of doing it.
    [emoji3]
    #7570
    New improved TW Ice Seal n Shine announced by Pan.
    YouTube
    Apr 2012
    #7571
    i still have 1 un-opened bottle of SnS. no detailing is done to my cars since i left in January. anyway, they are barely used during the lockdown period. maybe when i get home, i can re-apply the SnS and the Ceramic hybrid
    #7572
    Bro mine is still kalahati, matagal naman ang epekto and once a week lang ang labas for groceries.
    Sep 2016
    #7573
    Kahapon ko lang napansin nung nagpacar wash ako na may natuyong droplet ng cement sa hood ko. Di na matuklap eh. Nakita ko sa net pwede raw pantanggal ang vinegar + warm water. May nakatry na ba nito?
    #7574
    weak acid only, to avoid damaging the paintjob.
    also, try very carefully prising it away with one's fingernail.
    the longer the drop of cement stays on the surface, the more difficult it is, to remove it.
    Sep 2016
    #7575
    Sige doc try ko ulit mamaya. Di na kayang tuklapin ng kuko eh. Walang kanto na makapitan yung kuko ko para matuklap.
    #7576
    baka mas maganda pressurized water, or wd40?
    pero OK nga daw suka ..
    How to Remove Cement from a Car: 8 Steps (with Pictures) - wikiHow
    Jul 2016
    #7578
    pH care ginagamit ko. yes, the feminine wash. free lang kasi eh. [emoji4]
    Sent from my INE-LX2r using Tapatalk
    Apr 2012
    #7579
    Quote Originally Posted by x.mayor View Post
    ayos, intimate washing ba?[emoji6][emoji13] maybe United Laboratories try venturing into car care products. pH care intimate wash car shampoo[emoji39]
    Aug 2019
    #7580
    claybar can only remove dirt, grime ang other contaminants na kumapit sa paint, it cannot remove swirls and stubborn watermarks. if wala naman masyado contaminants, claybar at ipa wipe, ok na.
    ang ultimate solution sa prepping ay polishing, either by hand or using a polisher. by hand, you can use yung mga all-in-one or AIO products like klasse. if may polisher ka, a polishing compound is needed depende sa severity ng paint correction na gagawin. if not, isang pasada ng finishing compound ok na. megs combo ng 105/205 ang nasubukan ko na ok.
    kung wala ka polisher at gusto mo ma-prep ng maayos yung sasakyan mo bago mag TnS, you can have it polish by a car detailing shop near sa area mo then ikaw na lang mag-apply ng TnS. or you can bring the TnS and ask them na ang i-apply na last step product ay yung dala mo. then maintain mo na lang[emoji846]
    anong brand ng polisher pwede gamitin sir pag mag tatanggal ng "marring marks" na galing sa claying?
    ang ginamit kong clay is ung kulay blue lang sa lazada. then puro marks na ung auto pagkatapos. baka mali ako ng pag clay.
    ang nabasa ko pwede daw po tanggaling pag pinolish. ano po kaya pwede gamitin? hand polish lang din plano ko sir kasi wala akong machine.
    thank you!
"Tamang OC lang" - a newbie's guide to car appearance maintenance
