Page 391 of 392 FirstFirst ... 291341381387388389390391392 LastLast
Results 7,801 to 7,820 of 7833
    Oct 2023
    #7801
    1st time to do rotary machine polishing? give a try first in 1 section like sa bubong, that even you mess it up it will not be an eye sore. there are two types of polisher, a rotary and orbital. mas DIY friendly ang orbital. ang rotary pwedeng makayod masyado yung paint or worst masunog if hindi pa sanay ang gagamit. even the pads to be use depende sa texture at level ng coarseness kung pang cutting, polishing o finishing. carwash soap is paint coating and wax friendly. dish soap have degreaser so it strip the paint of any paint protection na nakaapply.
    Ok, I'll do the roof first. Also gives me another reason to remove the roof rack which I've wanted to remove for so long :P. Yup, I wanted to get a DA but even the cheapest one on shopee was out of my budget so I've just been watching vids on YT about how to use a rotary properly. The car has never been waxed but do you think I should just use dish soap anyway to remove more contaminants? As in is dish soap more aggressive than car wash soap? Also few more questions,
    - When claying, can I use soapy water as a lubricant?
    - Can I use acid rain remover around emblems to remove the dirt? (Saw a vid on yt about it but idk if it could hurt the paint)
    - Can I use soapy water after buffing the polish to remove the excess polish on the paint or should I just wash it again after before applying crystal fx?
    - How do I know when the polish has been exhausted and I need to stop? Magiging sticky ba or something?
    Appreciate your answers
    Apr 2012
    #7802
    Quote Originally Posted by palosean View Post
    - invest in a good orbital polisher and buffing pads, its your main tool. unless you do it by hand
    - as said earlier, dish soaps have degreasers and it can remove paint protection i.e. wax. but since magpolish ka naman so you can use it.
    - you can use car shampoo + water as clay lube. just ensure the mix have enough lubricity to effortlessly slide the clay
    - you can use acid rain remover but wash it down rightvaway else baka mamuti emblems. better still, use the bug & tar remover you have. it can remove stubborn dirts around emblems. need elbow grease though
    - wash and dry after polishing then apply your last step product
    - the polish will dry like dust. you must have a water spray bottle to always wet your buffing pads.
    and to add, you need a lot of buffing pads and detailing towels
    Oct 2023
    #7803
    Didn't think of using the tar remover for emblems, thank you, I'll definitely do that. As for the polisher, I just bought the cheap one since I'll probably only use it once or twice every few years since I don't think polishing should be done every year to save the clear coat. And anyway, I think I have a decent enough washing technique to not induce scratches haha. Also, I'm a student so I definitely cannot justify spending over 1k on a tool I'll barely use. I already have a lot of towels that I built up slowly over the past year or so so that should not be a problem. For the pads, is it ok to just use one pad and then clean it out after every panel? Like by using a stiff brush or washing/rinsing it?
    Answers appreciated, thank you!
    Apr 2012
    #7804
    try mo lang yung bug & tar. i used it before and it works, need lang extra elbow grease.
    i dont know what polisher and pad(s) you have but what i have are pads for specific purpose like cutting, polishing and finishing. and it matches the polishing compounds too
    Oct 2023
    #7805
    Safe ba sa emblems yung bug and tar na made from HCl? Yun kasi yung kinuha ko. For my polishing set up, here's what I have if it's worth anything (shopee links included)
    - Mitsushi rotary polisher 650W - https://shopee.ph/-BUY-1-GET-5-Mitsu...962.2614343799
    - Set of 5" pads (planning to use the green pad) - https://shopee.ph/11-8-5PCS-Buffing-...456.7983390942
    - Microtex supraone - https://shopee.ph/Microtex-MTX-Supra...81.22651449473
    Don't know if you have experience using those but anyway that's what I have. As much as I wanted to get better equipment, I only allot half of my weekly allowance for spending, the other half goes straight to my savings account, and when subtracting my transportation expense, I'm left with only ~300 or less so I unfortunately can't get really nice stuff for now.
    Oct 2023
    #7806
    Safe ba sa emblems yung bug and tar na made from HCl? Yun kasi yung kinuha ko. For my polishing set up, here's what I have if it's worth anything (double post but without the shopee links in case they aren't allowed or mods haven't been on for a while :P)
    - Microtex supraone
    Apr 2012
    #7807
    - Microtex supraone
    you apply lang sa mga outlines at crevices ng emblem na may nanigas na dumi...
    ok na yan, make use of what you have. glad that you have the urge to do paint correction sa car niyo. bihira yung kaedad mo na may hilig maglinis ng car.
    if you have time, read the first 10 or 20 pages of this Tamang OC thread. marami ka matutunan sa proper washing hanggang sa waxing post ni sir scharnhorst
    Oct 2023
    #7808
    I'll do that, thank you.
    Dad takes care of the running costs and PMS so I take care of the interior and exterior haha. He always tells me to just leave the exterior as it is and just keep the interior clean (and of course take care of the engine but he's the one taking care of that) because that's where we sit but I tell him, why not both? So I just do the interior first then exterior the week after and just alternate between them.
    I'll definitely read the first few pages, actually already started reading last night haha.
    Also, is it possible to upload pictures here without needing mod approval? Would like to share the before and after of my paint correction after I do it when we get back from holiday. Also planning to do a wheels off detail of the wheels if I'm free next week since I have the iron decon and bug and tar remover now.
    Apr 2012
    #7809
    yes, you can post pics.
    btw for the engine bay, the easy way to clean it, you can use the cheapest foam cleaner you can find. marami sa shopee (kulay yellow na can). you can just spray the foam sa engine bay then let it linger for few secs then wipe with a microfiber towel or any basahan na lint free. no need to apply rubber or plastic dressing, dagdag gastos lang.
    you can use also sa tire/rims, interior, dashbrd, seats, trims, even your kusina stove top na oily, its effective.
    Oct 2023
    #7810
    Got it, though yung ginawa ko sa old lancer namin before, I just used soapy water and a rag and brush haha. Effective naman and plus I didn't need to buy anything. I'll attach the picture from my archive below. For our montero, I'm planning to do the engine last. For the interior naman, I'm using microtex quickleen followed by sunshield for the dash and plastics and armorall leather care for the leather seat covers. I might try the microtex leather restorer when the armorall runs out.
    Apr 2012
    #7811
    well done. nice and clean engine[emoji106]
    Oct 2023
    #7812
    Thanks. I do miss that car, only got to drive it a few times before they sold it but that's a topic for another time
    Oct 2023
    #7813
    Hey all, quick update on my first paint correction. Still haven't tried the buffing machine but I just finished doing the door handles and mirrors. Decided to do it now since I had nothing to do and since I wouldn't have been able to use the machine on it anyway. Learned a lot even just hand polishing and claying and I really enjoyed it. Super satisfying too and I could not believe my eyes when I saw the difference. There still are a few scratches but they are really shallow and it's much better than when I started. You can only see it with a light so I'm really pleased with the result. Can't wait to finally do the whole car after our holiday. Before and after below.
    Apr 2012
    #7814
    good job[emoji106]...sure matutuwa ang dad mo
    Feb 2019
    #7815
    Recently bought a black car and can't help but noticed dust keep on accumulating in the vehicle and I have to wipe it everyday or every other day. Would a ceramic coating be of good help? so that I will not have to wipe the dust everyday or a PPF + ceramic coating? pros and cons? Thank you.
    #7816
    in my opinion,
    black cars attract white dust,
    just as white cars will attract dark/black dust, albeit will probably be less visible.
    my feeling is,
    the coating will make it easier to dust off,
    but it will not make the dust slide off spontaneously.
    another advantage of "coatings", is that paint spatters may be easier to remove.
    Apr 2012
    #7817
    common na yan sa black car, dumihin o madaling makita ang alikabok. sabi nga na kung gusto mo na hindi dumihin, get a gray colored car. i doubt if ceramic coating will help, it might in preventing swirl marks sa frequent dusting but not to prevent the dust in clinging sa paint surface. kung gusto mo talaga ma-lessened ang dust, have an enclosed parking.
    #7818
    yespo.
    four of our five cars, are silver. i can get away with dusting only the glass... the nylon duster i am using, does a better job than the usual natural product dusters.
    i got the bronze car, despite the color, because the price, provenance, and plate number, were right.
    #7819
    We have a neighbor, aliw ako kasi all 4 cars in their garage are White! That's the visible gate so I don't know if they have more cars dun sa kabilang gate na hindi white hahaha
    It's like that since forever, always white
    Jun 2011
    #7820
    Regular soft/liquid/spray wax na hand buffed lang. Tapos feather duster na light para iwas swirl.
"Tamang OC lang" - a newbie's guide to car appearance maintenance
