Guys can i use this just like how larry of ammo uses hydrate when drying the car?
Hi all. Any suggestion paano tanggalin residue ng fruit spit from bat or bird sa hood. Tried buffing w nanosliq and turtle bug and tar remover. No effect.
Sent from my RNE-L22 using Tapatalk
he already used one of the best bug and tar removers. but unfortunately it was too late(how long did you wait before using the bug&tar remover), it is now etched onto the wax or clearcoat. next step is to use the lightest abrasives.
prevention prevention. wax or sealant or coats or ppfs/foils...
I've heard that some people have successfully used alcohol-based hand sanitizer to remove tree sap, not sure if it would work in this case. I'd say it's worth a try before polishing/compounding. And I agree, protecting the paint is a lot easier than correcting the damage.
What do you guys put in your interior? Is quickleen safe to use for every wash? Or would you guys suggest something better
TD will likely advice to use a clay bar and quick detailer to remove those nasty stains. If this doesn't work, it's highly likely that some more aggressive cleaning approach will be needed, perhaps something similar with removing stubborn water spots.
I have an issue with stubborn water spots on my ceramic coated M3 (done at TD as well). It's frustrating that the clay bar approach is not enough so I'm going to try out CarPro Spotless and hopefully this product will resolve the water spot issue.
https://youtu.be/Il018tlKX7g
