Page 324 of 392 FirstFirst ... 224274314320321322323324325326327328334374 ... LastLast
Results 6,461 to 6,480 of 7833
    Apr 2012
    #6461
    Quote Originally Posted by bochokoks123 View Post
    Yung mga napatungan na water mark sir matatanggal pa ba yun?
    Sent from my SM-A520F using Tsikot Forums mobile app
    yes. you can always polish later. saka 1 month old lang car mo, mababaw pa watermarks. bka nga matangal pa yan kapag nagwax ka
    the factory clearcoat.... is it fully cured kaya?
    Nov 2016
    #6463
    If I polish later on do I have to reapply the wax?
    Oct 2003
    #6464
    *bochokoks123
    Mas maganda sana kung wash clay polish IPA wipe sealant and then wax. You can spread that out in two days. Worth it yan.
    Quote Originally Posted by zechs View Post
    *bochokoks123
    suggest panel by panel with swirl inspection?
    Feb 2014
    #6466
    last sept 2017 i purchased a car w/ aug 2017 production date (decoded from VIN). so i was wondering if the paint was fully cured already. based on what i've read the factory paint was supposed to have been baked thus fully curing it. as opposed to drying in the air naturally which takes a long time. though some repair shops do have IR lamps i don't think they can crank up the heat too much
    Nov 2016
    #6467
    *bochokoks123
    Gusto ko sana sir kaya lang di pa ko marunong and gusto ko na sana iwax the soonest since mejo ulan araw yung panahon natin and I dont have a covered garage.
    Sep 2017
    #6468
    Any body recommend a good beginner polish? Around 1 month rin car from casa here as well plan wash then clay before waxing. Polish is for future reference hehe.
    Apr 2012
    #6469
    you can re-apply wax every 3-4 washes or if nag-subside na yung wax. there is a thing called beading which you will notice kapag bagong apply ng wax, nagbuo-buo yung water, parang droplets. thats the hydropobic o water repelling properties ng wax. meron din sheeting, depende sa quality ng wax you use. check mo na lang sa google yung water beading at sheeting, di ako maka-post ng sample pic
    Oct 2003
    #6470
    Kung may time siya. Haha. Since new car naman, mas konti ang kailangan i-correct. Or have it done professionally na lang.
    Magandang polish is megs m205. Personally di ko pa na-try though. Meron pa akong chemical guys na scratch and swirl remover.
    Ako nagpapawax ako ng car or nagwawax ako if time permits. Favorite kong time magpawax pag umuulan. Sure na walang tao sa suki kong carwash. Remember ung wax ang sacrificial layer kaya mas gusto ko layer ako ng layer.
    Apr 2012
    #6471
    you can only say maganda if you tried na [emoji13]pwede 1 step polish ang m205 depende sa pad na gagamitin mo. but better to buy the combo of m105/205, they work in tandem and in synergy.
    Oct 2003
    #6472
    Baka too abrasive na for me ang m105. M205 muna para mas more on polish ung effect. White pad should work fine with that.
    Curious ako sa megs ultimate line kung okay or not hehe
    Apr 2012
    #6473
    for light swirls and defects, swak ang m205. ang m105 naman ay ang do-it-all polish sa gamit ko now. it gets the job done easily kasi. minsan skip ko na 205 since makinis na even under sa light.
    Sep 2017
    #6474
    Been reading and watching videos about IPA sprays. Looking to make a 10-15% blend to spray my car before waxing. Some people recommend mixing all purpose cleaner (a cap-full) to the mix for the surfactants.
    What do you think of this and what brand of APC is good for car paint use.
    Apr 2012
    #6475
    Quote Originally Posted by MamBad View Post
    i use the common isopropyl/rubbing alcohol mix 50:50 with water.
    #6476
    bro monty, di ba ito masyado matapang?
    btw denatured alcohol kaya pwede? parang mas mura kasi hehehe
    Apr 2012
    #6477
    di naman bro kapag diluted na sa water. yan din ginagamit mga detailing guru's dati sa pinoy detailing. IPA ka na lang bro kesa denatured lols! mas matapang yata yan. naalala ko yan pansindi ng coleman na ilaw nung araw...
    #6478
    ah ganun ba, thanks sa advice bro ^_^
    mas mura kasi denatured, akala ko less potent
    Oct 2003
    #6479
    Same here. 50:50 mix din ako then after IPA wipe pwede na ako mag klasse sealant and glaze. Cure 24 hours and then another coat of klasse. After that pure carnauba wax na as a topper.
    #6480
    Quote Originally Posted by rspayumo View Post
    Remembered a video I saw on Youtube from Dallas Auto Detailing.
    The Best Way To Use A Foam Cannon - Throw Away Grit Guard! - YouTube
    He hates the two bucket method. Ayaw nya yung idea na magbubuhat sya ng 2 buckets with almost 5 gallon water on each bucket. Tapos bibili pa raw ng Grit guards, etc.
    Sent from my GT-P5110 using Tapatalk
    To all tsikot detailers, ano ba yung ginagamit na chemical to make a foam?
    I will try to use it on my Nilfisk spray gun...
    TIA
"Tamang OC lang" - a newbie's guide to car appearance maintenance
