Hello, need help, I'm a confused sa mga buffing/polishing pad classifications, which of these should be used in what kind of pads? I'm planning to buy Microtex pads, I don't know if these are good items coz I find Meguiars a bit expensive.
1. CUTTING PADS - This is an aggressive pad and meant to remove heavy paint defects like heavy swirls, RDS, etc. You can use these products w/ this pad- Rubbing Compound
2. POLISHING PADS - This is a mild pad meant to remove light swirls and enhance shine of paint. These are the products you can use w/ this pad- Polishing Compound, Cleaner / Polish.
3. FINISHING PADS - This pad has NO cut, meaning meant for refining finishes w/soft paint. or wax or sealant application. These are the products you can use with this pad.- Polishing Compound (If you want need a little cut, and want to finish in one step). Cleaner / Polish, wax, sealants, Glaze (depending on the brand, some will be better applied by hand).
4. WOOL PADS - Most aggressive pads, can be used with Heavy rubbing compound.
Thank you.
I haven't tried Microtex pads, so I can't comment on how effect or durable these pads are.
I am also assuming you will be using a machine polisher for these pads, am I right?
