Page 26 of 127 FirstFirst ... 162223242526272829303676126 ... LastLast
Results 501 to 520 of 2535
    Dec 2009
    #501
    Quote Originally Posted by Ginnova View Post
    *paolo37
    try to use a compound else wet sanding and compounding/polishing should get rid of that yellowing.
    ok sir, salamat... try ko bukas...
    Apr 2011
    #502
    ask ko lang kung hinahaluhan ba ng water ang nanosliq? parang 50/50? pwede ba yun?
    Apr 2010
    #503
    hi sir snowblind, some of our detailing gurus here had experimented some 10 - 50% mixture of water, and produced some positive results, others reported that the haze which was seen after is less and others said much easier to remove..
    but together with the mixture.. others report that the shine it produces became less.
    I have been using NanoSliq for almost 2 years but havent got the time to experiment with the mixture since I cant see in comparison the changes since my van is colored white :D
    just to share lang
    Sep 2011
    #504
    Thanks umi001. Salamat sa lahat ng info.
    Sep 2011
    #505
    *jagg18
    here's my recommendation based on the products you currently have:
    1. instead of buying 915, i suggest you get klasse twins ( KSG and KAIO ) since you already have the ultimate quick wax. wax over a sealant would be a better combo. Klasse All in One ( KAIO ) will also be good alternative to a cleaner wax. so you hit 2 birds with 1 stone with the twins.
    2. instead of getting a mothers clay bar kit ( clay + lube ) , it would be better and more economical to buy a seperate clay only and ONR as clay lube. Showtime Instant Detailer included in the mothers kit is only good for 2 cars at most. ONR on the other hand , can be used for other purposes like clay lube, QD and rinseless wash. dilution for clay lube is 1:64 so it would be more economical.
    Hi Ginnova. Thanks sa input.
    Questions:
    1. Since wax over sealant is a good combo. Ipatong ko na lang kaya yung 915 sa KSG? Tapos uqw for maintenance para sa mga weeks na hindi pa nagdedeteriorate yung 915. What do you think? Yung nanoglos at nanosliq ko naman kasi yung small bottles lang. Yung nakapackage with a sponge. Kasi ittry ko lang naman dapat. Actually, gusto ko sa collinite is matibay daw. Hindi kaagad nawawala. Also, makintab raw siya compared sa 476. Gusto ko kasi makintab auto ko. Okay nga din sana yung Turtle Wax Ice kaso hindi lang ako sure dun. Hehe.
    2. Paano ba gamitin yang Klasse twins? KAIO can be used instead of a cleaner wax so minsanan lang paggamit nito no? I read somewhere na yung cleaner wax has abrasives so dapat minsanan lang ang paggamit. Tipong every 6 months lang? Iba ba itong KAIO? Saan ba sila nabibili? Big Bert's? Also, wala rin ako masyadong idea sa paggamit ng KSG and sa frequency ng paggamit nito.
    3. Sa ONR naman? Pwede bang pang shampoo ito? Tama ba pagkakaintindi ko? Hehe.
    Clay lube - pampadulas sa clay bar para hindi gumasgas.
    QD - substitute sa carwash? pag maalikabok/madumi/may bird droppings or tree sap? Spray then wipe lang. Hindi niya ba masstrip yung collinite/uqw?
    rinseless wash - no idea. haha. pangshampoo na hindi na kailangan banlawan? haha.
    Planned Routine:
    Initial routine: Wash -> clay -> cleaner wax(KAIO) -> KSG -> wax(915)
    Week 1: wash + KAIO + KSG + 915(dry,buff,cure)
    Week 2: wash only?
    Week 3: wash only?
    Week 4: wash + UQW
    Week 5: wash only?
    Week 6: wash only?
    Week 7: Repeat
    Pasensya na sir sa sobrang daming tanong. Total noob. First car e, hehe.
    Thanks in advance! :D
    Aug 2008
    #506
    Quote Originally Posted by jagg18 View Post
    Questions:
    Planned Routine:
    Week 2: wash only?
    Week 3: wash only?
    Week 4: wash + UQW
    Week 5: wash only?
    Week 6: wash only?
    Week 7: Repeat
    If you have the money, then you certainly do KAIO + KSG + 915, for more durable protection (though the Klasse twins are pretty durable by themselves). 915 should look better than the Klasse twins alone, though it does depend on what kind of look you like (the twins give a candy-coated look to paint, a little plasticky, while 915 darkens and deepens that paint). However, do note that most of the look is in the prep - i.e., claying and polishing. Waxes and sealants may add some gloss or depth, but most of the shine comes from having clean, defect-free paint.
    Apply KAIO using an applicator pad. Then, without removing the residue, you can apply the KSG immediately, very very thinly. Leave to dry and haze for an hour, and then remove. Let cure for 12 hours. You can use the KAIO + KSG combo every three months - it'll last that long, maybe longer.
    KAIO is different in that, though it is a cleaner wax (technically a cleaner sealant), it does not contain any abrasives - the cleaning it does is via chemical cleaners. That means that it is ok to use often - in fact, I use KAIO to clean my paint surface before applying a fresh coat of wax or sealant (about every 6 weeks). You can get the Carlack twins (pretty much the same product, different names) from Big Bert's, and I've also seen them at MC Home Depot.
    ONR is a very versatile product, with the uses you enumerate. Clay lube is to ensure that they clay does not stick to your paint and marr the surface; QD is spray and wipe, for light cleaning; rinseless washing is using a bucket and a wash mitt, use as you would a normal shampoo mixture, but no need to rinse with water - you can dry immediately. ONR will not strip your wax - in fact, it has polymers that will help prolong your wax or sealant layer. It's very convenient, and saves a lot of time and effort - in fact, I pretty much do just rinseless washes instead of conventional ones.
    The routine you posted would be ok, except that on week 7, you could probably just reapply your 915 (no need to re-apply the twins yet).
    Oct 2008
    #507
    if you have access to a covered area to do your detailing a few hours, get it. or watch the weather report and pull hairs while waiting for the applied product to cure.
    Apr 2011
    #508
    ah ok. thanks sir!.. tama po ba na kailangan ng 6 hours curing time(nano gloss) bago mo patungan ng nano sliq?
    Quote Originally Posted by olidotcom View Post
    just to share lang
    #509
    Quote Originally Posted by sn0wbLind View Post
    yung nanoglos needs some curing time before patungan ng ibang product. 4 hours would be enough.
    #510
    Questions:
    Planned Routine:
    Week 2: wash only?
    Week 3: wash only?
    Week 4: wash + UQW
    Week 5: wash only?
    Week 6: wash only?
    Week 7: Repeat
    most of your questions were already answered by umi
    my recommendation of the twins was based on the existing products you already have at the moment. but if you have enough cash to buy klasse twins and 915 then that combo would be better. but for that amount combined i would go for a permanent coating like Cquatz, opticoat. mahirap din mag-collect ng mga LSP baka hindi mo maubos.
    the twins plus your ultimate quick wax would be more than enough protection. but the key to achieve excellent results lies in paint preparation. to achieve this you would need a machine ( dual-action polisher ie. PC7424XP, G110 , Griots etc ). i would suggest you save for this one rather than collect duplicate LSP's.
    Oct 2011
    #511
    What particular wax & polish brand is the best out there in the market that would give you the superb showroom shine? Preferably wax & polish in 1. I don't like a separate one for wax and another one for polishing. Thanks.
    WBR,
    #512
    *umi - puno na pala inbox mo.
    Aug 2008
    #513
    Nye - ok, let me delete some older mails, give me 10 minutes.
    Aug 2008
    #514
    WBR,
    90%+ of looks comes from the prep. You need to have your car's paint in perfect condition - no embedded contaminants, and swirls and scratches polished out - to get a proper shine. The choice of wax or sealant would only add 10% or less - waxes and sealants are more for protection. So, make sure your car's paint is in good condition - this will require polishing and (maybe) compounding. Afterwards, any product would look good - heck, I've seen some good-looking posts on other detailing forums using Turtle Wax Hard Shell. Conversely, the most expensive Zymol or Swissvax wax will not make swirly, cloudy, scratched paint look good.
    Also, just to define terms (as commonly used - note some companies use them differently) - a polish is a product that is used to level/abrade the paint, in order to remove swirls and scratches. A wax (or sealant) is a product used to protect the paint, preventing contamination from sticking and preventing UV damage to the clear coat. So these serve two different purposes. Sure, there are products that do both (usually called all-in-ones or cleaner waxes/sealants), but as with all things, it is (generally) better to use products made for specific purposes, rather than jack-of-all trade products.
    Aug 2008
    #515
    Hehehe, I agree - buy a DA and pads, you'll get more out of them than collecting different LSPs (ask me how I know...). With what I've spent on waxes and sealants, I could easily have bought a DA and pads already, and have made my life easier with regards to product application (thankfully, the car is still in pretty good shape, so not much need for a polish). So get a durable LSP, get a booster wax, paint cleaner/cleaner wax, some clay, then save for the machine. After that, you can go ahead and try out different LSPs if you like, if you have the money, though the difference in look isn't likely to be too drastic on well-prepared, good-condition paint.
    Sep 2011
    #516
    Maraming salamat Ginnova and umi001!
    Magexperiment muna ako sa manual. Ipon experience points muna bago ko subukan mag mechanical. :D
    #517
    Yes ganyan muna...
    Oct 2008
    #518
    WBR,
    velcum to tsikot. and here in DTfN (get out while you can :lol. for polishing what? scratches? polishes leave on oils for the paint but not much of a protection. i like your want for simplification but i dunno of one. if it's strong enough to remove scratches then it may well remove itself.
    in the middle, for minor blemishes, a wax with cleaners like Collinite's #885, Fleetwax, a cleaner wax in paste form with the durability known of Collinite waxes. pls ask autobisyo if they have this. #870 is liquid Fleetwax.
    or you can try the ubiquitous albeit less durable Turtle Wax Carnauba Cleaner Wax or either of the M's cleaner wax. Generally carnauba waxes have some cleaning capacity because of the solvent that make the carnauba soft for application. Sealant AIOs have even milder cleaners than these.
    Oct 2011
    #519
    Quote Originally Posted by umi001 View Post
    okay, thanks for your enlightment bro. well said.
    #520
    Detailed. Wash > Clay > Asphalt removal > Wash > GLOS > 915 > SLIQ
Detailing Thread [For Newbies][continued 3]
